New motor upgrades
Old May 20, 2012 | 11:10 PM
jarebear86's Avatar
jarebear86
Default New motor upgrades
So I just bought a motor from a buddy of mine it's the 5.2 out of a 98 that I'm gonna drop in my truck bc my rings are messed up and this is just gonna be easier to build and do the swap over the weekend. Then I'm gonna rebuild the one in my truck and drop it in my offroad toy. But just trying to see what y'all would suggest I do to the motor before I drop it in my truck. The truck is a daily driver truck and will be my tow rig for my toy (jeep). So I'd like to have good amount of power (plan on doing gears) but what's some stuff Yale would suggest to do to the engine. Like I said the motor will be out of the truck so all upgrades should be easier to do.
Old May 20, 2012 | 11:15 PM
dlyter09's Avatar
dlyter09
Fix the plenum while its out. Do some HS 1.7 replace the plugs wires and rotor... I mean how much $$ you wanna spend??
Old May 20, 2012 | 11:17 PM
SilverSS's Avatar
SilverSS
Is it a new motor? If not how many miles? Are you looking for preventative maintenance while it's out or performance upgrades?
Old May 21, 2012 | 12:22 AM
gdstock's Avatar
gdstock
Double roller timing chain with the HS Rockers, maybe airgap if you want to drop that much into it. No way would I do this without replacing water pump as well, and throw on an e-fan.
How's the tranny? Add tranny cooler, check valve delete, remote filter.
Old May 21, 2012 | 12:45 AM
johnnyjaws98's Avatar
johnnyjaws98
hows the compressiom?
Old May 21, 2012 | 12:28 PM
jarebear86's Avatar
jarebear86
Old motor trying to make it last forever it's got 112000 on it my tranny is just been rebuilt 10000 mile ago planned on doing plneum and wires etc. Compression is perfect. What's hs 1.7? I'll spend some good money on it to make it last but just remember I'm not building a race motor just a daily driver tow rig that I wanna gain some power out of.
Old May 21, 2012 | 12:30 PM
dlyter09's Avatar
dlyter09
Harlan sharp roller rockers. Get some Odessa heads and get the air gap intake. Should make for a good peppy and reliable motor... and of course an SCT tune to top it all off
Old May 21, 2012 | 12:42 PM
gdstock's Avatar
gdstock
+1 on the Odessa Heads. Probably the best bang for the buck. HS rockers will improve performance, but not necessarily make it last longer. Same with airgap and tune. Double Roller timing set (about $58) will not only help overall performance, but it will last longer than a new Morse chain.
The HS rockers (about $350), the airgap, and the tune ($265) will make it perform better and therefore increas owner satisfaction with your Ram.
If money is the concern, start with the heads, plenum, and timing set, and of course a new water pump and probably new oil pump to be safe. The other items can be added as you can afford it. If you do the plenum plate and later go with the air gap, I know you can sell the old intake to another Ram owner - as soon as you educate him about the plenum issue and get him to look inside his intake!
Old May 21, 2012 | 03:11 PM
SilverSS's Avatar
SilverSS
I would put a small cam in it also.
Old May 21, 2012 | 06:25 PM
johnnyjaws98
and fuzzy dice
