A/C, MAP sensor wire harness
Old May 21, 2012 | 10:10 PM
jamesnb's Avatar
jamesnb
Default A/C, MAP sensor wire harness
The signal wires to the A/C compressor and to the MAP sensor broke, from heat I guess. I spliced the wires back together with butt crimps but I'd really like to replace both sets of wires from the AC connector back and from the MAP Senor back.
Has anybody had to do this?
Do the wires terminate at the PCM?
Is this a pretty straight-forward job?
Any idea on the price of the harnesses?
2001 Ram 1500 5.9L Gas by the way.
Thanks
Old May 21, 2012 | 10:12 PM
Grab the 01 service manual from the faq section, and have a look at the wiring diagrams. Some wires hit splices here and there.... they also like to change color.......
Old May 22, 2012 | 01:04 AM
jamesnb's Avatar
jamesnb
Yeah, I looked at the manual and it was kind of confusing, that's when I asked if anybody had replaced them.
Old May 22, 2012 | 12:09 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You most likely would have to replace the entire engine harness. You'd be better off getting some shrink wrap, a soldering iron, solder, some die electric grease. And some split tubing to protect it.
Old May 22, 2012 | 08:06 PM
jamesnb's Avatar
jamesnb
Yeah, the dealer said they only sell a pig-tail or the engine harness (for like $1200). If/when this repair fails, I'll probably get new pig-tails and make a solder joint.
I used the higher quality butt connectors and shrink wrapped them. I also added some additional split tubing.
Old May 22, 2012 | 09:58 PM
gdstock's Avatar
gdstock
You should be good then. I prefer solder personally with heat shring and new convolte tubing. Heat and age make the plastic brittle.\\I am going to pick up AC connectors and a few others for the engine the nest time I am at a JY. I prefer to make an adapter for splicing things in such as e-fans to keep from making a rats nest of wiring.
