99 ram v6 oil pressure
Old May 25, 2012 | 08:42 AM
Tony Bertram's Avatar
Tony Bertram
Default 99 ram v6 oil pressure
I have a 99 ram 1500 v6 that sat for about 2 1/2 to three years at my dad's place. The truck has a little over 53000 miles on it and now that I have it back, I did an oil change after running a bottle of motor flush through it to clean the old oil out of it. I noticed when driving, the oil pressure doesn't stay steady, the gauge will drift down when going around corners or up slight hills. The pressure when running at idle is about 60 psi and at around 50 when driving. When turning a corner the gauge drops to about 25 but never to 0. Before changing the oil I didn't notice if the gauge drifted or not. What all could cause the pressure to drift when turning or going up a hill?
Old May 25, 2012 | 11:21 AM
Low oil level, or bad sensor. Maybe a clogged pickup tube...... probably wouldn't hurt to drop the pan, and see what you find.
Old May 25, 2012 | 03:00 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The oil should have been changed before start up after sitting that long. Check what HeyYou stated. And just my opinion, but, using the flush as you did was a big mistake as far as I'm concerned.
Old May 25, 2012 | 03:44 PM
Tony Bertram
Thanks, looks like I'm on the way to get a new Oil Pan Gasket and might as well pull the covers while I am at it.
Whats wrong with using Motor Flush, that's what the Dealer used on my wifes PT Cruiser at 100000?
Old May 25, 2012 | 04:14 PM
zman17's Avatar
zman17
It could very well be the part of the problem you are having. When it sits like that condensation/water builds up in the motor.
Old May 25, 2012 | 07:57 PM
Motor flush......
Most of them are pretty much just kerosene, with some additives. Maybe. Not exactly a good lubricant. If you don't follow the directions EXACTLY, you can destroy bearings in short order.
