how to fix speedoand after 3.92 gears.
Old May 25, 2012 | 11:35 AM
dodgeman2289's Avatar
dodgeman2289
Default how to fix speedoand after 3.92 gears.
was told my speed sensor is in my tranny. so how do i get me speedo to be accurate again?
Old May 25, 2012 | 11:43 AM
billcart's Avatar
billcart
The rwal sensor should take care of it. If it is off it will only be around 2 miles or so. When you change tires is when it can go haywire. A performance tuner can help.
Old May 25, 2012 | 11:51 AM
He has a 97, speedo gets it's cue from the VSS in the trans, which, fortunately, is gear driven. Change the gear, and you are all set. Transmission center sells the gears, and even has a chart to help you pick the right one.
Old May 25, 2012 | 02:01 PM
billcart's Avatar
billcart
Ohhh. Thank you for the lesson. I will pass that along to some friends of mine here locally.
Old May 25, 2012 | 02:02 PM
I think it was in 98 that they went to the rear wheel speed sensor doing the speedo also.... and since it reads from the tone ring, changing gears doesn't affect it, tire size does though....
Old May 26, 2012 | 04:41 PM
dodgeman2289
ok so where do i go or wut do i type in to find the part i need?
Old May 26, 2012 | 05:27 PM
Have a look here.
Old May 26, 2012 | 10:32 PM
dodgeman2289
thanks i guess i gotta call cause idk what one to buy
Old Jun 8, 2012 | 10:00 PM
Tation's Avatar
Tation
Hey Dodgeman, where did you get your 3.92 gears at? I need to upgrade mine.
Old Jun 9, 2012 | 11:45 AM
dodgeman2289
i bought jasons off this site.
