Trans service coming up, sensor/solenoid question
Old May 26, 2012 | 02:49 AM
sarmikgar's Avatar
sarmikgar
Default Trans service coming up, sensor/solenoid question
Getting ready to service my trans in the next week or so, I have the B&M drain plug kit and a couple of Wix filters ready to go.
I need to get some fluid still, but I was also thinking of doing the governor solenoid and sensor while I was in there.. maybe bands too.
Ive been searching and cant find any for sure answer on this, I found the link below in an older thread, and I think it will fit, just wanted to double check since the ad only lists 98-99:
http://www.ebay.com/itm/DODGE-JEEP-4...527#vi-content
Can anyone tell me if this is the correct parts for my 1996?
Thanks much.
Old May 26, 2012 | 10:04 AM
The electrical connectors may have changed. They also have the listed for other year trucks. Get a set that are indeed for your year....... that way, you KNOW they will work.
Old May 26, 2012 | 11:47 AM
FFFD827's Avatar
FFFD827
im putting mine back together today. I got my type 4 fluid from napa. They had the best price for a reliable brand. Dose anyone know the torque specs for the pan i didnt see any in the manual. I have a ft lb and inch lb torque wrenches.
Old May 26, 2012 | 12:05 PM
FFFD827's Avatar
FFFD827
I found it. 13ft lbs
Old May 26, 2012 | 12:25 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Thanks much.
The Governor Solenoid is all that really needs replace. And cleaning yours if you are having no problems is just fine. If you are going to replace it anyway, get one of these from a local tranny shop, or order one from PATC or here, http://www.doghousediesel.com/catalog/i307.html . And just for future info, why would you order a part from some place(even though theoretically it might fit?) for something that fits on some vehicle not your year, or make for that matter.
Old May 26, 2012 | 12:54 PM
sarmikgar's Avatar
sarmikgar
That was my worry that the connector may be different.
Maybe Ill just clean mine up then, just figured while in there Id replace the parts I can.
I find ebay sellers often dont know everything about their parts as far as fitment, and many times will list limited years/models or even the same parts in multiple ads listed for different year/make/model. I wouldnt order till I found out for sure it would fit, thats why I was looking for some confirmation on this great forum. Thank you for the link to an alternative source for the parts.
Old May 26, 2012 | 02:49 PM
zman17's Avatar
zman17
Why take the chance? Anyway, since you are doing all the other right stuff, I highly suggest you get the BorgWarner solenoid.
Old May 26, 2012 | 08:48 PM
Jimythefan's Avatar
Jimythefan
..........snip........ http://www.doghousediesel.com/catalog/i307.html.............
Bookmarked, thank's for that link zman.
Old May 26, 2012 | 10:18 PM
gdstock's Avatar
gdstock
Want to save $10 AND free shipping? And this guy does know......Same BW part, better price.
http://www.ebay.com/itm/330602331148...84.m1497.l2649
Old May 26, 2012 | 11:23 PM
sarmikgar's Avatar
sarmikgar
I went ahead and got both parts through the link zman provided, was $145ish with shipping. Going to pick up some fluid, and an extra drain pan tomorrow so I am ready to do the job when they get here.
Ive been searching(there is ALOT of posts with "drain plug" in them), but cant find any info on where to drill for the drain plug.
Is there an optimal spot for me to put it?
