Front wheel bearing hubs
Old May 26, 2012 | 08:39 AM
Obiejuankinobie's Avatar
Obiejuankinobie
Default Front wheel bearing hubs
I purchased two wheel bearing hubs for my 1500 2whl drive 2001 Dodge Ram. I am old school. To change the front wheel bearings all I had to do was pull them out put new races and bearings done. Now I have to bust my butt pulling hubs. I never done this before. Do I need a air impact Hammer (the one that looks like a chisel on the end) I do know I have to use the impact wrench to remove the big nut. Tips how to any help will be greatly appreciated. Thanks bunch
Old May 26, 2012 | 09:55 AM
Change it out just like any other unit bearing. (hub/bearing assembly) The nut that holds it all in place is torqued at something near 175 ft/lbs..... so, don't expect it to come off willingly. I believe on the 4x2's, that nut is not reusable either....... Should say as much on it if that's the case.
Old May 26, 2012 | 10:05 AM
mccart's Avatar
mccart
Just pull the nut off and the hub then the new one on
Old May 26, 2012 | 11:34 AM
Obiejuankinobie
Thanks on on it.
Old May 26, 2012 | 11:50 AM
Ol_RedRam's Avatar
Ol_RedRam
I didn't use a impact to get the big nut off of mine. I used a piece of 1'' ridgid conduit as a cheater bar and jumped up and down on it for five minutes. After that, it's no big deal. Slide old off, slide new on. Might oughta pick up a new cotter pin, as well. Just a heads up.
Old May 26, 2012 | 12:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
97 is different than a 2001. And is yours a 4x4 or 2wd? Might want to add that bit of info to your sig and profile.
Old May 26, 2012 | 12:33 PM
that would make a great youtube video......
