e brake clamp?
Old May 26, 2012 | 11:09 PM
on my friends rear end the thing that all the main springs go around broke and i guess it let the rest go including the adjusters. not many of the pieces that fell out where identifiable. most of it somehow ground down to almost nothing.
I had a gremlin (AMC) do that to me once.... took off the drum, and ALL the brake parts hit the parking lot.....
Old May 26, 2012 | 11:22 PM
gdstock's Avatar
gdstock
The gremlin had gremilins?
Old May 26, 2012 | 11:52 PM
Big time..... the car was pretty much indestructible though... I beat the SNOT out of that car, and it didn't even notice. Off Roading, fire roads, delivery driver in a huge city, all sorts of rude and nasty driving, in all sorts of nasty weather..... (Upper Peninsula for awhile....) It just kept going.
Old May 27, 2012 | 12:01 AM
dhvaughan's Avatar
dhvaughan
see if this helps.
https://dodgeforum.com/forum/2nd-gen...-pictures.html
Old May 27, 2012 | 12:04 AM
gdstock's Avatar
gdstock
Lots of good shots with it all together. That should help OP. The pics in the FSM did not match my truck. Had heck of a time trying to reconstruct that mess.
Old May 27, 2012 | 11:25 AM
zman17's Avatar
zman17
Retired Moderator - RIP
They(dodge) changed the configuration quite a few times through the years. Which is why having a Haynes, FSM and only doing one side at a time is so important.
Old May 27, 2012 | 11:58 AM
cutthroatxxx's Avatar
cutthroatxxx
Originally Posted by dhvaughan
Thanks but I meant the cable clamp that attaches to the frame before the cannister.I looked@another truck&figures out mine was m.i.a. I fixed it.Thank a ton guys
Old May 27, 2012 | 12:11 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Are you talking about this clamp?
Did they change what side the ebrake runs on years? Mine is driver side.
Old May 27, 2012 | 12:21 PM
gdstock's Avatar
gdstock
I would not think there would be much to change on that - for thirty years or so! But I have never seen the need to jack with that. Only disconnecting at the shoe lever.
Old May 27, 2012 | 12:29 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by cutthroatxxx
Ok so doing my bl&instructions say to remove the clamp from parking brake cable but I see no clamp,am I missing something?
I think you are referring to this clamp:
I got the wire out of the wire connector that is the farthest forward. I didn't have a long socket on the adjuster. That would be the best way. Then unhook. Just remember the location to the best you can for adjustment.
