nv3500 swap
Old May 26, 2012 | 08:13 PM
Nortzy's Avatar
Nortzy
Default nv3500 swap
ive got a 98 4x4 ram with a 46re and it just let go. i have a nv3500 5 speed laying around from my old 2 wheel drive. can i put a new output shaft on the nv3500 and use it will it bolt to the x-fer case?
Old May 26, 2012 | 09:23 PM
Matt Nickerson's Avatar
Matt Nickerson
Here's a 46rh-->NV3500 swap in a Dakota 318ci
So here is the list of parts that are needed...
  • Transmission
  • Transfer Case (if 4x4)
  • Brake/Clutch pedal assembly with hardware
  • Hydraulics (master cyl, lines, and slave cyl... comes as an assembled, non-serviceable unit)
  • Flywheel (engine specific)
  • Bolts - Flywheel to crankshaft (same thread pattern as flex plate bolts, must be 1 inch long and grade 8)
  • Bolts - Pressure plate to Flywheel (don't remember the pattern or length, but they must also be grade 8)
  • Clutch kit (clutch plate, pressure plate, throwout bearing, pilot bearing)
  • Pilot Bearing Sleeve (Best to get it direct from Dodge.. PN 5300 9180 for 3.9L and 5.2L)
  • Manual transmission specific crankshaft position sensor
  • Rear driveshaft (if you can't find a factory one, you can get one custom made... needs to be 7 inches longer)
  • Front driveshaft (if 4x4... if you can't find a factory one, you can get one custom made... needs to be 7 inches shorter)
Get all these things ahead of time and the swap can be done in a weekend!
Taken From Here: https://dodgeforum.com/forum/1st-gen...-5-2l-4x4.html
Old May 26, 2012 | 09:27 PM
Nortzy's Avatar
Nortzy
i understand i need all that thanks for the input ... but is it possible to take the tailstock off the nv3500 and put a new output shaft on it and bolt it up to my transfer case?
Old May 26, 2012 | 09:39 PM
Matt Nickerson
Yup I believe that's all ya gotta do. Swap out the input shaft of the transfer case as they are different sizes
Old May 26, 2012 | 10:50 PM
Hahns5.2's Avatar
Hahns5.2
No.
And no.
The entire main shaft and rear half of the tranny case needs to be swapped, requiring complete disassembly of a difficult to rebuild tranny.
Old May 26, 2012 | 10:53 PM
gdstock's Avatar
gdstock
Certainly more work and $ than rebuilding. Probably higher than buying a mega viper, and not as good a tranny to boot. Not to mention adding clutch pedal assy, cuttin hole in floor.....
Nortzy's Avatar
Nortzy
difficult wouldnt it be easier than a 46re to rebuild? imo it is, and weve done a few at work
Old May 26, 2012 | 10:57 PM
Nortzy's Avatar
Nortzy
if it isnt just a new input/output shaft driveshaft and clutch then no its not worth it.
Old May 26, 2012 | 11:02 PM
Hahns5.2's Avatar
Hahns5.2
I disagree.
How many "mega vipers" out there have 215k on them with 35k of boosted small block in front of them?
NV3500 has my respect.
Old May 26, 2012 | 11:03 PM
gdstock's Avatar
gdstock
There are other issues that will come up. PCM controls tranny fundctions and looks for signal voltage from tranny. Not seeing these, codes will pop. To resolve, an appropriate PCM swap would be required.
I bought my Ram with a blown tranny, knowing it was blown. I rebuilt it myself using the FSM downloaded form this site.
