I have a serious issue. When I push the brake and the gas down at the same time the engine rpm kicks up a bit and nothing happens. I wana light those rear tires up any ideas?
There the tires that came from the dealer in 98 and they are pretty dry rotted. I want to smoke em off before I get new tires but I'm having the problem above.
If no work has been done to the motor there's a fair chance the plenum is blown or at least a bad pcv valve which will foul out plugs and clog catalytic converter's which all rob power.
If you're holding down the brake and floor the gas pedal the rear outta brake lose on stock size'd tire's.
