trouble with 2000 dodge ram 1500 5.2 v8
Old May 30, 2012 | 10:37 AM
  #21
Make sure to use shorter bolts, or, washers on current bolts for the plenum. They were a bit too long from the factory.
Old May 30, 2012 | 01:27 PM
  #22
patoman_12's Avatar
patoman_12
ok man so im chinging it till tomorow but ill start today...i went to buy the gaskets and then the truck shut off 3 times while driving....i would put drive and my truck would turn off and had trouble turning it on.. algo while accelarating i could hear some squieking on the engine...after i came home the check engine light came on and it threw the code p1391...im so stressed dont know what to do!!!!!!!!!!!!!!!!!!!!!
Old May 30, 2012 | 02:02 PM
  #23
zman17's Avatar
zman17
Retired Moderator - RIP
Changing the plenum gasket is not the end of it. If the gasket is blown so is the cat.
Old May 30, 2012 | 02:05 PM
  #24
patoman_12's Avatar
patoman_12
cat is out...how do i know if plenum is blown
Old May 30, 2012 | 02:10 PM
  #25
patoman_12's Avatar
patoman_12
sorry fot the 1000 questions just that im having trouble with it
Old May 30, 2012 | 02:17 PM
  #26
patoman_12's Avatar
patoman_12
could the map sensor be the trouble??
Old May 30, 2012 | 06:44 PM
  #27
P1391 Interm Loss of CMP or CKP
The would definitely cause it to stall..... since both sensors are new.... I would take a look at the wiring from sensor, to PCM.
Old May 30, 2012 | 08:16 PM
  #28
patoman_12's Avatar
patoman_12
the crankshaft is new but not the cam sensor..ok i just called autozone and supposibly it doesnt have a cam sensor..also i took the manifold and found out deres was a gap beetwen the manifold and block...also took out the plenum gasket and it was carbonated and it was in pieces.,..
Old May 31, 2012 | 04:55 PM
  #29
zman17's Avatar
zman17
It's also called a pick up coil.
Old May 31, 2012 | 09:53 PM
  #30
patoman_12's Avatar
patoman_12
well i just change the plenum gasket and it got worse it overheated and possibly blown head....but thats it im selling and getting something else thanks for ur help anyways really appreciate it
