My Performance Plan-What do you think?
Old Jun 2, 2012 | 11:29 AM
  #41
Big Joe C's Avatar
Big Joe C
So I just jacked up my truck and tried it out. And sadly...I have an open diff.
I spun the one tire and the other one spun in the opposite direction. So now idk if it's completly open diff or the LSD is worn out becuase there no build sheet, no sticker on the axle, and the sticker in the glove box is there, but worn out to where you can't read what it says. Is there a way to still get a build sheet from Chrysler? And mabey put an LSD in my truck?
Old Jun 2, 2012 | 11:36 AM
  #42
Decide what size tires you want to run, pick gears accordingly, and do the locker/posi at the same time as gears. Otherwise, you get to pay for setup multiple times.. and it ain't cheap. (unless you can do it yourself.)
Check This out to get a build sheet.
Old Jun 2, 2012 | 01:05 PM
  #43
Wombat Ranger's Avatar
Wombat Ranger
If you decide to install an LSD, spend some extra dough and get something better than a Trak-Lok. They suck. I would get an Eaton Truetrac if I were to go LSD. Do a google search to learn more
Old Jun 2, 2012 | 04:45 PM
  #44
Big Joe C's Avatar
Big Joe C
Ok thanks I'm going to have to look into it.
Old Jun 2, 2012 | 07:09 PM
  #45
Johnny2Bad's Avatar
Johnny2Bad
Originally Posted by stewie01
I believe that "posi" is a GM term.
I think it's Anti-Spin Differential on our trucks. And it depends on the option's from the factory, if it's 4x4 chance's are it's got a LSD rear end, if it's 4x2 I'll bet it's an open diff but you can either 1. Get a build sheet from Chrysler, will have all the option's for your truck, 2. Check the sticker in the glove box (if it's still there, if there's NO mention to LSD or Anti-Spin then you have an open diff) or 3. They put sticker's on the axle itself, chance's are it's gone but you can give it a look too.
I went from 16"s to 17"s but choose what I found to be the normal stock tire size for a 17" wheel...
And even if your truck has an open diff it IS possible to spin both tire's.
Posi-Traction refers to specific GM limited slip differentials. For the most part people who claim they have a "Positraction" diff really don't ... as far as I know GM only used the trademark during the 50's and 60's and only on GMC and Chevy 12-bolt trucks. It's possible some of the early predecessors to the Muscle Car, around 61-64 might have referred to it that way in literature, but I've never seen it. The Truck and Passenger car 12-bolts are not identical.
GM always referred to it as "Posi-Traction" (with the hyphen and capital T). My dad's 12-bolt equipped 68 Pontiac's owner's manual and sticker on the trunk lid (warning for jacking the car during a tire change) called it a "Limited Slip Differential"; the word "Posi-Traction" never appeared anywhere on the car or the documentation.
It's basically come to be a generic term for LSD, like "coke" for cola, "Band-Aid", etc. So, since almost no-one, including GM car owners, actually has a Posi-Traction rear diff even if they do have a factory LSD, I generally just accept it as a generic term, not in reference to a specific part.
Old Jun 2, 2012 | 07:13 PM
  #46
Originally Posted by Johnny2Bad
Posi-Traction refers to specific GM limited slip differentials. For the most part people who claim they have a "Positraction" diff really don't ... as far as I know GM only used the trademark during the 50's and 60's and only on GMC and Chevy 12-bolt trucks. The Truck and Passenger car 12-bolts are not identical.
GM always referred to it as "Posi-Traction" (with the hyphen and capital T). My dad's 68 Pontiac's owner's manual and sticker on the trunk lid (warning for jacking the car during a tire change) called it a "Limited Slip Differential"; the word "Posi-Traction" never appeared anywhere on the car or the documentation.
Yeah, posi-trac became kind of a generic term for limited slip diffs back in the day, and it has carried over thru today. GM actually used a variety of different methods of accomplishing 'traction adding'..... my personal LEAST favorite was the Gov-Loc rear diff...... I can't count the number of those I saw in grenaded condition.
Old Jun 2, 2012 | 07:18 PM
  #47
Wombat Ranger
Moral of the story is....
We all know what someone means when they refer to an LSD as Posi.
Old Jun 2, 2012 | 07:22 PM
  #48
How do you get Lysergic acid diethylamide out of Posi?
Old Jun 2, 2012 | 07:39 PM
  #49
Wombat Ranger
Well if it's out of a 60's or 70's car/truck.......
Old Jun 2, 2012 | 09:01 PM
  #50
DK-v1's Avatar
DK-v1
Timing chain and gears
Any preferences on chain/gear brands?
