dodge 1500 jumping rpm with codes p1391 and p1682
Old May 31, 2012 | 12:12 AM
jones21's Avatar
jones21
Default dodge 1500 jumping rpm with codes p1391 and p1682
the past two years I have been working on this dodge ever since I sank the tranny and now after I have everything put back together it hasn't ran the same.
with jumping rpm and back firing also showing codes of p1391 and p1682
Old Jun 3, 2012 | 11:29 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
The P1391 is the loss of a crank or cam sensor signal. Since you had the transmission out, I would look at the sensor wire. It maybe pinched in the bellhousing. I going to move your post to the 2nd Gen Ram section.
Old Jun 3, 2012 | 11:46 PM
gdstock's Avatar
gdstock
Originally Posted by master tech
Welcome to DF
I would check the wiring as referenced and even go as far as to remove the sensor and check the end of it for wear or crap built up on it?
Old Feb 26, 2024 | 04:56 PM
DAVIDE's Avatar
DAVIDE
Default Struggling with same codes!
I know this is an old thread but I'm at my wits end with this 98 with a 318 (5.2l) that im dealing with... identical symptoms and codes. I am hoping you found a solution! Any help would be appreciated.
Old Feb 27, 2024 | 08:19 AM
Hasn't been here in more than a decade....
Start your own thread, detail what the problem is, and what troubleshooting you have done.
