engine build?
Old May 31, 2012 | 10:12 PM
sam_priem's Avatar
sam_priem
Default engine build?
im building up a new engine for my truck. goin 408. some of the stuff that i look at ask me whether its a small block LA or a small block magnum. i know i have the magnum but my question is the difference between the two. what things differ from the LA to the Magnum?
Old May 31, 2012 | 10:56 PM
mccart's Avatar
mccart
Only differences I know of are that the heads are different and the magnum is fuel injected. Not sure about anything else but I'm sure there are other things
Old May 31, 2012 | 10:59 PM
Ham Bone's Avatar
Ham Bone
The Magnum is esstentially a somewhat "modernized" version of the old LA series.
A quick google search will tell you the differences
Old May 31, 2012 | 11:49 PM
Hahns5.2's Avatar
Hahns5.2
Top end oiling is different and motor mounts are different, among other things.
Old Jun 1, 2012 | 01:05 AM
working4ev's Avatar
working4ev
This book will answer all your questions..
http://www.amazon.com/Build-Big-Inch.../dp/193249457X
I got this book and it opened my eyes to the possibility's are engine have..
There are a lot of differences between LA and Magnum.
Old Jun 1, 2012 | 09:06 AM
Sooper's Avatar
Sooper
How are you getting to a 408? Stroking a 360?
I'm only curious because I have a complete donor 360 on a stand ready for a rebuild to go in my 1998 Durango and I've been contemplating what direction I want to go with it.
Old Jun 1, 2012 | 09:23 AM
Yep, increased stroke, bore the cylinders, and you end up with a 408. There are kits available to do so. (crank, connecting rods, pistons and pins, etc.) Not an inexpensive endeavor though....
Old Jun 1, 2012 | 10:17 PM
sam_priem's Avatar
sam_priem
i went onto hughes engines this morning and saw that i could even go to 426. can i really go that big? im gettin a fully assembled engine for $150 plus i got some extra money to play with. would the extra CI's be worth the little extra money?
Old Jun 1, 2012 | 10:29 PM
Johnny2Bad's Avatar
Johnny2Bad
A stroker is a stroker ... it doesn't cost that much more (or less) to vary displacement once you bite the stroker bullet. Basically you buy the same parts while a few details vary. A new custom ground crank crank is a new custom ground crank. Find out if there are extra steps (eg block machining and clearancing) that the usual stroker motors might not require.
Old Jun 2, 2012 | 12:04 AM
Wombat Ranger's Avatar
Wombat Ranger
The kits with more than a 4" stroke seem to be quite a bit more expensive, at least in my experience. That might be because the block needs more machining/clearancing done to it. With a 4" stroke clearancing requirements are minimal, from what I've read.
