Conversion???
Old Jun 1, 2012 | 12:32 AM
tavo98's Avatar
tavo98
Default Conversion???
i have a 98 dodge 2wd ext. cab, ive been wanting to put in the new front the 2008 front, is it possible to customize it to fit or not? thanks in advance
Old Jun 1, 2012 | 12:37 AM
dodgeram07's Avatar
dodgeram07
Sure cut,grid,weld,fill,smooth,paint,injoy
Old Jun 1, 2012 | 12:39 AM
tavo98's Avatar
tavo98
Smile
is it alot of problems? will it look good cut? it wont look weird? thanks for replying
Old Jun 1, 2012 | 06:04 AM
stewie01's Avatar
stewie01
Find an '08 to compare to, get some measurement's of the front of both trucks, go from there. Will it look weird? Depends on your style. It's probably gonna be a lot of work though.
Old Jun 1, 2012 | 09:30 AM
Are you talking about the front sheetmetal? Or the front driveline? (converting to 4x4)
Old Jun 1, 2012 | 11:52 AM
Ramzy's Avatar
Ramzy
If you are talking sheet metal that, IMO, would be way more work than it's worth.
Old Jun 1, 2012 | 12:26 PM
EndIsNear's Avatar
EndIsNear
I've seen the bumper done, but a whole front end conversion would be nearly impossible. I'm sure it could be done, but it would never look right. Body lines don't match up, and you'd be fabricating more parts to make it work than what the actual conversion consisted of. If its just the bumper, just minor trimming can make it fit.
