I think I found a V10 Mods list?
Old Jun 4, 2012 | 10:02 PM
Brian NY V10's Avatar
Brian NY V10
Default I think I found a V10 Mods list?
Ok, so I am new to the V10...but I've been turning wrenches for 30 years. During my hunt for data on the web I came across a list some guy made in 2004. I am looking to make this Ram of mine the best it can be, so let me know what you all think of this list. If it has been shared before then I apologize for redundancy...be well:
Performance computer Mopar 94 95 ALL P5249548
Performance computer Mopar 96 All P4876133
Performance computer Mopar 97 Federal P4876473
Performance computer Mopar 97 Cali P4876471
Performance computer Mopar 99 Federal P5007131
Performance computer Mopar 99 Cali P5007132
Performance computer Mopar 00 Federal P5007211
Performance computer Mopar 00 cali P5007212
Computer Chip Jet Stage 1 97 to 02 90013
Computer Chip Jet Stage 2 97 to 02 90013S
Engine management Roe Racing Roe Racing controller
180 Degree T stat NAPA Weirstat #613080
Offset Camshaft Keys Mopar P5249600
Camshaft Mopar P4876060
Camshaft Crower Idle to 5000K 84565
Camshaft Crower 1000 to 5700 84566
Camshaft Crower custom V10 grind 00060
Camshaft Comp Cams 800 to 5000 98-315-10
Camshaft Comp Cams 1200 to 5200 98-325-10
Camshaft KRC 218/224
Roller Rockers Crower 1.6 ratio 73657K
Roller Rockers Crower 1.7 ratio 73659K
Forged Pistons Ross 94 to 02
Throttle Body Fastman 52mm
Throttle Body Fastman 53mm
Throttle Body KRC
Throttle Body Magnum performance
Air Filter K&N 94-02 #33-2058
Cold Air intake K&N 57-1507
Intake Manifold KRC
Headers PPH
Headers JBA 97-02 #1950S
Headers Mopar 94-95 ALL P5249763
Headers Mopar 96-02 Cali P5249966
Headers Mopar 96-02 Federal P5249967
Headers Gibson ALL GP304
Cat back Gibson 94-02 Side Ext Cab, Short bed 316511
Cat back Gibson 96-02 Side Ext Cab, Long bed 316570
Cat back Gibson 94-02 Side Reg Long bed 316510
Cat back Gibson 96-02 Split Rear 6503
Cat back Mopar 96-97 Cali Long bed P4876276
Cat back Mopar 94-02 Federal Long bed P5249764
Cat back Mopar 98-02 Cali Long Bed P4876849
Cat Back Magnalow 98-02 15616
Supercharger Paxton Novi 2000 94 to 01
Boost/Nittous timing box MSD 94 to 02 # 8962
Nitrous Nitrous Express 100-250 Horse #20234
High perfomance Plug wires Mopar 94-02 P4876434
High perfomance Plug wires Taylor 94-02 74x73
Companies
http://www.truckperformance.com
http://www.Krcperformance.com
http://www.crower.com
http://www.compcams.com
http://www.summitracing.com
Old Jun 4, 2012 | 10:08 PM
I think KRC performance is gone now.
Some of the parts are probably discontinued as well... (like the supercharger kits. possibly some of the cams....)
Someone actually made a performance intake for the truck 10? Really? That would be interesting to see.
The 10 is already a stump puller...... Seems to me with just headers, good exhaust, and a good tune, you could squeeze some more ponies out of it.
What year is your truck? (should but all the info about it in your sig. )
Old Jun 5, 2012 | 09:15 AM
Brian NY V10
Mine's a '94...Not really looking to blow her up with mods...but I'm the kind of guy who ripped an old XBOX 360 apart for the cooling heat sinks and then epoxied them to my ATI video card to get 3 degrees cooler running temps....Since it is the first production year and she looks so damn nice; I just want to keep her alive and the more avenues I have for parts or aftermarket goodies the better.
Old Jun 5, 2012 | 09:55 AM
I am familiar with that philosophy.
Help it breath first. Headers, good Y-pipe, or even true duals. I think you only have one O2 sensor to contend with? Go with at least 2.5 inch pipe on duals. I think just doing that alone will make a noticeable difference.
The problem you are going to run in to is, once you start moving past bolt-ons, you are going to need to clue in the PCM as to what's up, and how to play nice with the new toys. OBDI (which you have) aren't flash programmable, you are going to have to send it out to have it tuned, and that runs right around 250.00 a pop. A standalone system that is easily programmable with a laptop, and the right cable might be cheaper in the long run. (not to mention you can custom tune your engine yourself, while looking at all the live data. That's a nice perk.)
Old Jun 5, 2012 | 08:47 PM
Brian NY V10
Actually all my research paid off! I just got an email this morning from a fellow who can burn a chip for the OBDI PCM....You think true duals would be better than 2 into 1? With or without a crossover? I hear Magnums like a bit of pressure, (although the 10 is just Magnum parts in a fancy Y block). I am in the works to replace the "submarine" size muffler and I'm debating a performance 2into1 like Magnaflow, or running glasspacks individually. I don't want to contend with running straight pipes so poppers in front of the rear wheels would be nice. I don't want to be arrogant; but I like a little noise...
Engine Performance Chip [info@engineperformancechip.com]
Here's the email...
Hi Brian,
Thanks for your email. We do have some options available for your Ram 2500 with the 8L V10. We would highly suggest going with our X3 chip with O2 sensor control.
The X3 chip has the following benefits:
1. LED indicator light
2. Best tuning curves and maps
3. Auto adjusting control for seamless switching between power/economy modes 4. Oxygen sensor control to have more control over the ECU chip
Currently that product is on sale for $149.00, so it is a great time to buy. We also have our base level X2 chip available for $69.99. If you have any other questions please let us know.
Sincerely,
What do you think? Never heard of these guys...
Old Jun 5, 2012 | 10:40 PM
Snake oil. While it may make some difference, all it is doing is fooling the engine into thinking the intake is cooler than it really is, and intercepting the O2 signal, so the PCM won't figure out that it actually isn't, and compensate for it. Their claims are outrageously inflated. (also note, it says "Up To" 20% power increase..... leaves them lots of wiggle room against false advertising lawsuits.)
Not a good solution.
Old Jun 5, 2012 | 11:27 PM
EndIsNear's Avatar
EndIsNear
I would just go with the standalone computer from Megasquirt... lots of headaches can be solved with a little extra cash.
Old Jun 6, 2012 | 06:51 AM
Brian NY V10
I didn't think so either. Unless I can get a programmer for the OBDI; then I am not even going to mess around with the PCM. I've never been a fan of throwing chips around to begin with...if I don't need a breaker bar to get it out...it ain't quality! I'm gonna keep her stock and if I want performance (which means speed) I'll hook a beaver tail up and tow the Porsche to the track!
