maybe buying a '98
Old Jun 9, 2012 | 05:59 PM
ytlogger's Avatar
ytlogger
Default maybe buying a '98
Hello all, I'm new to the forum as I don't own a dodge(yet). I am going to look at a '98 2500 quad cab 4x4 with 24 valve Cummins and automatic, about 140000 miles, tomorrow. Any particular issues to check out?
Old Jun 9, 2012 | 07:32 PM
Moochoff's Avatar
Moochoff
12v or 24v..? Different things to look for they changed half way through the year. also check cumminsforum!
Old Jun 9, 2012 | 07:59 PM
stewie01's Avatar
stewie01
How much $$$$$?
Old Jun 9, 2012 | 08:38 PM
shorty24v's Avatar
shorty24v
OP said 24v
Old Jun 9, 2012 | 08:56 PM
97tn4x4's Avatar
97tn4x4
The 53 blocks are known to crack.
Old Jun 10, 2012 | 03:36 PM
ytlogger's Avatar
ytlogger
Wow, cracking blocks is the only thing to worry about! I better get a few of these trucks..
Old Jun 10, 2012 | 03:43 PM
Wombat Ranger's Avatar
Wombat Ranger
The steering usually can use some freshening, if not a completely upgraded system. The dash's crack. The unit bearings are prone to failure. The ABS never works, and sucks when it does. The 47re's that come behind the Cummins are a decent trans, but can still give some fits. The vp44 injection pump needs a strong lift pump (and constant fuel pressure) behind it or it WILL commit suicide. Oh, also you will probably go through rear tires often
There. Ya happy?
Old Jun 10, 2012 | 03:51 PM
BLACKSHEEP757's Avatar
BLACKSHEEP757
Originally Posted by 2x1972
the steering usually can use some freshening, if not a completely upgraded system. The dash's crack. The unit bearings are prone to failure. The abs never works, and sucks when it does. The 47re's that come behind the cummins are a decent trans, but can still give some fits. The vp44 injection pump needs a strong lift pump (and constant fuel pressure) behind it or it will commit suicide. Oh, also you will probably go through rear tires often :d
there. Ya happy?
x2 pretty much covers it...........
Old Jun 13, 2012 | 09:16 PM
ytlogger's Avatar
ytlogger
Thanks guys. The dash isn't cracked at all. I'm looking into the rest. It is idling around 900 rpm. The present owner says it was flashed up for winter starting/idling. Hmmm...
