Possible Tranny or TPS Problem
Old Jun 12, 2012 | 04:14 PM
Bohunter768's Avatar
Bohunter768
Default Possible Tranny or TPS Problem
I had to replace the Tranny after mine had went out. Tranny was slipping and RPM's would go up when trying to accellerate. Bought a used one off of a guy I know that had just wrecked his and I know that it was working great when the wreck happened. After I changed the Tranny, I took it for a test drive and everything was working great, Strong from the start and shifting well, until it reached Operating Temp. I was going at highway speeds and had to slow down to make a turn and that is when the tranny didn't want to shift ane the engine seemed to be real sluggish and didn't want to get over 1500 to 2000 RPM's. The best that I could do was get it to change into 2nd then limp the last mile home. I let it sit overnight and the same thing happened the next day. Real strong and responsive at first. Went on vacation for a week and then tried to move it yesterday but now the engine is sluggish and non-responsive even when cold. Tranny seems to want to move but the enging won't get up and go.
Thanks in advance. Any and all help would be appreciated.
Old Jun 12, 2012 | 04:21 PM
Remove the pre-cat O2 sensor, and see if it runs any better.
Old Jun 12, 2012 | 06:48 PM
Bohunter768
Thanks for the sugestion HeyYou but forgive my ignorance when it comes to O2 sensors. I have been working on my own engines since 1982 but have not had to deal with any O2 sensors at all.
After I pulled the Pre-Cat O2, I left it Hanging and plugged into the harness, cranked and reved the engine without any hesitation. I am assuming that the sensor is "BAD", or is it telling me something else is wrong?
Old Jun 12, 2012 | 07:14 PM
Telling you your cat is plugged up.
Old Jun 12, 2012 | 08:15 PM
gdstock's Avatar
gdstock
....and that means the plenum gasket is probably gone and the O2 sensor will need to be replaced when the cat is replaced....
Old Jun 13, 2012 | 12:00 AM
Bohunter768
Thanks. Will proceed with this info.
Old Jun 13, 2012 | 03:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
And use NTK o2 sensors from Rock Auto. There is a thread in the 2nd gen general discussion area that has a discount code also.
