tsb re route have you&do I
So just wondering has anybody done the tsb plug wire re route&if so any good results?I've done a search&got a little info but not much.just wondering because I'm doing my valve covers cap and rotor I am thinking about doing it but just do not have all of the stock clips so if it's worth it I'll take the time to get it done but if it's pointless then I won't
Wire routing is important and will become more so as wires age. Get regular clips from local parts store. Maiint hing, kee[ coil wire from crossing plug wires, and plug wires from crossing each other. I was missing factory wire looms also.
And mkae sure you get rotor snapped into place correctly, as if it is not down all the way, it will wreck out rotor and cap. Also, do NOT turn distributor.
I never did the TSB, but then I have an '01. I think the TSB was for earlier years (dont remember). Whether it matters or not I dont know. Also I got Summits tune up kit. Has 8mm wires I believe and no problems as far as I can tell.
Theres really not much of difference in expensive wires or cheap wires. I did a science project on it in governors school.
Unless you get the ultra expensive copper core wires there's literally no difference between two different brand of wires with the same insulation thickness
The cheap wires would actually cause less interference because of slightly higher resistance
Thats where a lot of people make the mistake. A 7mm wire vs a 8mm wire, the only difference is in the insulation thickness.
Trending Topics
There is no difference is correct, unless the wires are old bad/and/or cheap crap. And you have a misfire. So why wouldn't the OP just do it?
I put brand new Taylor 8.2 mm spark plug wires on my truck to help eliminate spark knock. I just ran them any which way and then took the truck for a drive they did help reduce the spark knock but not as much as I hoped.
I then ran the wires as per the tsb which was a b$@:& took it for a drive and the spark knock was drastically reduced, almost to the point of being gone.
