Carrier for the 9.25
Old Jun 15, 2012 | 10:27 PM
merc225hp's Avatar
merc225hp
Some gear noise is to be expected, but not a lot. If you are worried about the noise go back to the shop and Bit** hard. I now understand why you asked about the lash.
Old Jun 15, 2012 | 10:43 PM
dlyter09's Avatar
dlyter09
Originally Posted by 99ram360sport
^^^ Dlyter I am following the gear brake in procedure in the gears section in the DIY/FAQ . I have not taken the truck over 75 km/h which is 45 mph have been varying my speeds and driving 15 minutes then sitting for at least 20 minutes.
Ok that's good.. I killed my first set by not following the procedure right so I like to stress the proper break in lol
Old Jun 15, 2012 | 11:50 PM
gdstock's Avatar
gdstock
Yep....back to the shop I would go! I have never heard any rear end noise on any vehicle I have owned, and there is and has been many of them.
So I see the break in procedure you guys are talking about.....but why is this not applicable to new vehicles? Are they run in at the factory or something? I've bought new trucks before and fromthe get go - drove 'em like I stole 'em! Never had a diff problem. just wondering.
Old Jun 16, 2012 | 12:38 AM
merc225hp's Avatar
merc225hp
I heat cycle new automotive r&p gears two times, then drive it normally, never had an issue. There are lot's of op's on this, some drive them hard from the get go others baby them.
Old Jun 16, 2012 | 11:20 AM
99ram360sport's Avatar
99ram360sport
Merc, you just drive for 20 minutes then let them cool off twice and that is it? That would be much easier than what I am doing.
Old Jun 16, 2012 | 12:45 PM
merc225hp's Avatar
merc225hp
Yes that is all "I" do. How many Km on those new gears?
Arde's Avatar
Arde
That's essentially what I did. A couple of trips of 10-12 miles, cooling off between, and then don't worry about it. I bought my diff. from Yukon and that's their recommendation for break in. I only have about 300 miles on it since the rebuild and haven't done anything hardcore. I'll take it easy at least until the 500 mile lube change, after that who knows.
Old Jun 16, 2012 | 12:55 PM
99ram360sport
Merc there is 80 km on the gears now.
