This has got to be strange, pressed my horn the other day and RT blinker came on (brightly), and not only that the wipers came on in the 3 wiper mode , like when you press the fluid button.....hmm, bet i have a grounding problem?. anyone xperience this with your rams???? so had to disconnect fluid plug and even swapped horn plugs, but if i diconnect horns....blinkers work like a blub went bad....very fast pulse. Any ideas out there????
