Tranny running hot
Old Jun 23, 2012 | 01:52 PM
  #21
QuadCabLuv's Avatar
QuadCabLuv
Originally Posted by zman17
After you buy all the adapters and double flare tools to install that $19 hunk of metal in the line, you'll spend the same or more money and a lot more time installing. Good luck, hope it works out for you.
Thanksfor your optimism but i wont need any of that. Just a couple of 3/8" barbed fittings and hose clamps that i alreadt have. So no it only cost me $26.
Old Jun 23, 2012 | 02:49 PM
  #22
gdstock's Avatar
gdstock
Have you found out why tranny is running hot?
Old Jun 23, 2012 | 09:24 PM
  #23
QuadCabLuv's Avatar
QuadCabLuv
no still waiting on all the parts to come in so i can do a full service.
Old Jun 23, 2012 | 09:57 PM
  #24
Flush the cooler and lines while you are waiting.
Old Jun 23, 2012 | 10:47 PM
  #25
97black_ram's Avatar
97black_ram
Originally Posted by QuadCabLuv
So ive been driving for a week or so with this trans tenp gauge and its always hovered around 175 deg. Buy today it rose to 200 and wouldnt kept climbing had i not stopped. I wasnt carrying a load and i was driving in the coty with the od off. I didnt even stop at any traffic lights, kept a pretty constant speed of 45 mph. So whats the deal here? Is mu one transmission cooler not enough since its bypasses the radiator?
How big is the cooler your using? I ask cause I've also bypassed the radiator and run this cooler: http://www.jegs.com/i/Flex-a-lite/400/3826/10002/-1
I see temps at about 150 on the freeway and driving around in the city stop and go it hits 180, but eventually cools off. I have also deleted the check valve and put an aluminum trans. pan on.
Hit 210 today for a sec and i shut it off. Im really hoping that a fluid change filter and the govenor and selonoid fix the issue. Im wonderin about adding a trans oil pressure gauge.
Running 210 for a short period won't hurt anything. I went wheeling last month got a little stuck and eventually got out and was at 240 on temp. Let it idle for a while in Neutral and it cooled off and continued my day. Oh and I got 200k miles on my 46re transmission. I simply change the fluid as needed.
Old Jun 24, 2012 | 12:48 PM
  #26
zman17's Avatar
zman17
Retired Moderator - RIP
Good luck dude.
Old Jul 29, 2012 | 10:24 PM
  #27
QuadCabLuv's Avatar
QuadCabLuv
i think i figured out why my tranny runs hotter. i need smaller tires or higher gears. I am running almost 33"s with the stock 3.55 gears in the d60. It does fine when im not pulling a load but anything over 1k and driving in the city it starts running hot. I am going to start saving up for some 4.10's. I am almost 100% sure that is my problem. anyone else wanna chime in?
Old Jul 29, 2012 | 10:51 PM
  #28
candymancan's Avatar
candymancan
Im running the largest hayden cooler they ha available at orielys, its rated dor 10k plus gvwr. I have nOt deleted the check valve yet. It didnt give me this problem last week
FYI 10,000 GVW is what you would run in a small compact car lol.
You need a 22,000 GVW or larger cooler for these transmissions. Also if you have bigger tires and small gears your transmission will overheat... Thats why you see a lot of Ford owners burn their tranny's up because they put gigantic tires on and the gearing is small, and the transmissions burn up.
Im running a hayden cooler, and its the 3 Loop cooler rated at 22,000 GVW... Im not sure what my tranny temp is running at tho as i dont have a gauge installed but its bypassed the main radiator, and my Jeeps temp warning light for the tranny has never come on
Check to see if the check valve is working or not.. Unhook the rubber line coming out from the cooler have someone hold it in a bucket or position it as best as you can.. Turn the truck on put it into neutral and then flip it off.. See if tranny fluid came out
Old Jul 29, 2012 | 10:54 PM
  #29
QuadCabLuv's Avatar
QuadCabLuv
I have already deleted the check valve. The specs i gave on that cooler may be incorrect. It was the largest one they offered, meant for a RV.
Old Jul 29, 2012 | 10:59 PM
  #30
candymancan
This is what im running, sorry bout the grill being in the way lol, btw its Jeep yea but its got the 5.9 and 46re, I've been thinking of getting a better one, this one is like basic IMO, and the previous owner kind attached it a little low so the full thing doesnt show "if that matters ?" I might get one of those fun style coolers they are supposedly better then the tube style.
My only concern sorta is that the previous owner bypassed the main rad and the tubes have been sitting open to the elements so i drive in the winter with it bypassed. I know the tranny does get warm/hot as i drove 5 minutes and felt it but i dunno
http://i1083.photobucket.com/albums/...2/HPIM1685.jpg
http://www.oregonperformancetransmis...egory_Code=HAY
