Tranny running hot
Old Jun 19, 2012 | 04:06 PM
QuadCabLuv's Avatar
QuadCabLuv
Default Tranny running hot
So ive been driving for a week or so with this trans tenp gauge and its always hovered around 175 deg. Buy today it rose to 200 and wouldnt kept climbing had i not stopped. I wasnt carrying a load and i was driving in the coty with the od off. I didnt even stop at any traffic lights, kept a pretty constant speed of 45 mph. So whats the deal here? Is mu one transmission cooler not enough since its bypasses the radiator?
Old Jun 19, 2012 | 04:14 PM
BamaRam97's Avatar
BamaRam97
Have you checked your tranny fluid? Maybe you have a leak. Post up what cooler you put in. It may not have enough cooling capacity to cool the transmission fluid as compared with the radiator.
Old Jun 19, 2012 | 06:22 PM
Have you gotten rid of the check valve??
Old Jun 19, 2012 | 06:40 PM
gdstock's Avatar
gdstock
That is too hot. Mine runds around 140 to 150 in normal driving.
Old Jun 19, 2012 | 06:44 PM
QuadCabLuv's Avatar
QuadCabLuv
Im running the largest hayden cooler they ha available at orielys, its rated dor 10k plus gvwr. I have nOt deleted the check valve yet. It didnt give me this problem last week
Old Jun 19, 2012 | 06:45 PM
Nuke the check valve first. You can just drill it out, and then blow the car out of the hose, (don't forget the spring) and reinstall it. See if that makes a difference. (I bet it will)
Old Jun 19, 2012 | 07:45 PM
QuadCabLuv's Avatar
QuadCabLuv
i hope it does. I havent had to tow any weight with it yet but almost all my new parts came in today which means its time to get it ready for towing.
Old Jun 21, 2012 | 07:27 PM
QuadCabLuv's Avatar
QuadCabLuv
so check valve delete did not fix the issue. I am hoping that a fluid and filter change may help that. There is no telling what the po put in it for fluid. I would like to change the governor and selonoid while im at it. I recall seeing a certain brand recommended several times but it slips my mind right now and i cant seem to find it through a search. anything else i should do while i have the pan off? besides adding a drain plug.
edit: the brand was borg warner right? also im guessing i have a 46re?
Old Jun 21, 2012 | 09:27 PM
QuadCabLuv's Avatar
QuadCabLuv
is it just me or has diesel manor lost their minds? I knew that the fitting was about $30 but then they want almost $14 for shipping. It will fit in a envelope for gods sake. The smallest flate rate box at USPS has 8x the room it would need and those are $5 shipped.
Old Jun 21, 2012 | 10:24 PM
Yeah, but, you are forgetting the 'handling' charge.... those guys get dollars per second..... It's indeed insane.
Borg Warner is correct. You do have a 46RE.
