Cylinder 8 Misfire after plenum fix
Old Jun 21, 2012 | 09:30 AM
  #41
Yeah, I suspect a stuck valve, or, a holed piston..... might be as simple as carbon buildup... but, probably have to tear down to inspect.
Old Jun 21, 2012 | 11:57 AM
  #42
merc225hp's Avatar
merc225hp
All the op comp test numbers are low, don't even mess with the motor it's whipped. Get a long block and be done with it. By the time you get the org motor fixed it will be way past the cost of a rebuilt motor.
Old Jun 21, 2012 | 12:03 PM
  #43
dlyter09's Avatar
dlyter09
Yea those numbers arent the greatest.. I agree with merc.. start looking for a new motor
Old Jun 21, 2012 | 12:14 PM
  #44
Think I am gonna third that motion, after taking a better glance at the numbers. Time for a new motor methinks.
Old Jun 21, 2012 | 12:45 PM
  #45
QuadCabLuv's Avatar
QuadCabLuv
I would at least pull the valve cover and main ign wire off and have someone crank it while you watch for the valves to be moving properly before gettin another motor.
Old Jun 21, 2012 | 12:51 PM
  #46
merc225hp's Avatar
merc225hp
Waste of time, the other numbers don't constitute any more effort to be put in it.
Old Jun 21, 2012 | 02:42 PM
  #47
Cylinder 2 was 110 psi
cylinder 4 was 100-105 psi
cylinder 6 was 120 psi
cylinder 8 was like 0 psi.
cylinder 1 was 100 psi
cylinder 3 was 95 psi
cylinder 5 was 110 psi
cylinder 7 was 117 psi
2,5,6,7 are "ok" but, getting close.
1 and 4 are marginal....... bordering on failure.
3 and 8 are both fails.
None of the numbers are really what I would consider "good"..... It's really time for either a new one, or a rebuild.
Old Jun 21, 2012 | 03:41 PM
  #48
tmacie's Avatar
tmacie
I'll fourth that. With how cheap these motors are for a long block its hardly worth more than a few minutes of troubleshooting after seeing those compression numbers.
Travis
