1997 ram 1500 pick up fuel problem
Old Jun 20, 2012 | 05:00 PM
mitch_miller's Avatar
mitch_miller
Default 1997 ram 1500 pick up fuel problem
out driving the other day, i reached over and turned on the A/C and immediately started losing power, i nursed it a few more miles before the engine died. quick check shows no fuel pressure. voltage checks are good, relay swapped. still no pressure. about to go under and check at the tank. does anyonw know of a tie in between the A/C and fuel pump that would cause this?
thanks!
mitch
Old Jun 20, 2012 | 05:58 PM
jasonw's Avatar
jasonw
Site Moderator
https://dodgeforum.com/forum/dodge-r...s-section.html
