What is missing?
Old Jun 22, 2012 | 01:39 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It's easy and not a problem to block off the EGR and plug the tubes. Problem is, there is nothing you can do about the CEL. I say replace it like it is suppose to be. Unless of course you like seeing the CEL.
Old Jun 22, 2012 | 01:52 PM
Wombat Ranger's Avatar
Wombat Ranger
^^^ I hate the idea of running burnt dirty exhaust gasses through the motor repeatedly. I would have already done this if I knew how to block the exhaust manifold.
Old Jun 22, 2012 | 02:03 PM
zman17's Avatar
zman17
Like I said, if you don't mind the CEL, it's easy. And there is threads related to blocking it off. Nothing can be done about the CEL though.
Old Jun 22, 2012 | 03:47 PM
Wombat Ranger
It throws a code once in a blue moon as it is. Not super worried about it, if my motor is running healthier for it
Old Jun 25, 2012 | 07:17 PM
Gord.'s Avatar
Gord.
Well I rechecked the codes today and I was wrong about which code I was getting. I have a code 32 for egr system failure, not for taking too long to warm up, and I also have a code 12 for "Direct battery input to PCM was disconnected within the last 50 key-on cycles (normal)" which I find a little odd since I haven't disconnected the battery recently. I was getting the egr code even before I eliminated it because it was clogged up.
^^ This is the biggest reason that I wanted to eliminate the egr in the first place. Once you take a good look at the system it really is easy to eliminate the egr. The 96s had a factory block off plate on the intake, which was easy to figure out, and the exhaust side I believe is held on with two bolts so that is pretty easy to block off. I only plugged one vacuum line, and removed the rest.
Gord.
Old Jun 25, 2012 | 08:44 PM
Hahns5.2's Avatar
Hahns5.2
Mine never ran quite right with the EGR deleted on the stock PCM, every once in a while I'd get a nice backfire through the intake. If it's tuned to expect EGR, it's not gonna run quite right when it's gone, just some food for thought.
But now with MS it's not a problem
Old Jun 25, 2012 | 10:42 PM
Wombat Ranger
Gord.
Thanks for the help! I probably won't get around to this (or much else with the truck) until late august at the earliest, since my fiance is coming down to visit me in 2 weeks
Hahns, you know I want to It all comes down to money... and it probably will not happen for a good while because of that. Anyway, thanks for the pointers.
