Replacing Infinity System
Old Jun 25, 2012 | 02:07 AM
COL's Avatar
COL
Default Replacing Infinity System
I know this has probably been asked by far too many times, but im going to have to ask it again. (I searched but had a hard time finding results for the second gen) I want to replace my badly blown stock infinity system, kinda on a budget too cause i have to pay for gas in the 5.9 pig. lol Should i go component, or coax? And i have heard you have to do extra wiring when it comes to the infinity system, so whats the process. I will let you know a aftermarket deck is already installed, and i plan on installing my kenwood sub and amp into the truck.
Old Jun 25, 2012 | 08:42 AM
Need to bypass the amps for the door speakers. I think that's about the only major thing you have to worry about.
Old Jun 25, 2012 | 07:31 PM
rollinlow's Avatar
rollinlow
easiest way and quickest? run new speaker wire from the deck to each of the speakers since you already have a aftermarket deck and run your rca cables and your power wires and be done with it.
Old Jun 25, 2012 | 08:13 PM
COL's Avatar
COL
That sounds like more work than just figuring out the factory wiring
Old Jun 25, 2012 | 08:23 PM
What year is your truck? (info that should be in your sig, and profile.)
Old Jun 25, 2012 | 09:50 PM
COL's Avatar
COL
I have a 1996 Dodge Ram 1500 SLT Laramie Sport 4x4 extended cab with the magnum 360c.i. 5.9L engine. lol. yup, its a mouthful.
Old Jun 26, 2012 | 07:25 AM
rollinlow's Avatar
rollinlow
if you just change speakers in the doors and rear and use factory wire yeah itll work but youll be able to tell.
