Gas in intake manifold
Old Jul 4, 2012 | 08:58 PM
  #21
aofarrell2's Avatar
aofarrell2
@gdstock, When an injector starts to misfire/miss, its spray pattern is not correct or may not be complete. The injectors are leaking anyway, and a downstream O2 sensor is at least $120, about the same as replacing the injectors. Not saying that it couldn't be an O2 sensor either, just that I know that I need to do injector work. @ HeyYou and @stewie01, 20K pounds is more than the full ton truck of the same year with same engine and HD tranny is rated at. But we have never found it to lack power, we might just come down to 45 MPH on hills @ 4900RPM in 1st gear, but after we do upgrades the engine will handle it better. The transimission has 147K on it but hasn't slipped at all. As for the brakes, they are OEM brakes from the factory, but are the largest ones you could get at 14inch. We have a brake controller and brakes on the trailer. Before we used this flatbed, we had a 16-foot cattle trailer without brakes, and that took as much as a semi to stop. But it is an amazing truck.
Old Jul 5, 2012 | 03:55 AM
  #22
bwdakrt's Avatar
bwdakrt
Check here for the O2 sensor http://www.rockauto.com/catalog/raframecatalog.php and if you do decide on changing injectors do a search on ebay for a remanufactured set of 19# Ford 4-hole injectors. Will give you a lot better fuel flow pattern and a smoother running engine.
Old Jul 5, 2012 | 12:57 PM
  #23
Wombat Ranger's Avatar
Wombat Ranger
OP you should post pictures of this towing madness
Old Jul 5, 2012 | 01:36 PM
  #24
aofarrell2's Avatar
aofarrell2
@bwdakrt, Have you used those Ford injectors in your Dodge truck? @2x1972, I was going to get pictures but I was up till 5 in the morning with a flat tire and when I got up at 10 they had unloaded already. I have some past pictures and we are going to tow a 24' gooseneck sometime I will get pictures.
Old Jul 5, 2012 | 03:08 PM
  #25
bwdakrt's Avatar
bwdakrt
Sure do. Been running them for about 5 years now and love 'em. Easier starts, smoother idle, a little better mpg and butt dyno says a little more power.
There's 2 different styles...EV1 has the rectangular shaped connector for '92-'99 models and the EV6 has the oval shaped connector for the '00 + models.
Here's a plug and play set for your truck at a real good price. http://www.ebay.com/itm/8-BOSCH-19LB...6b948b&vxp=mtr
Old Jul 5, 2012 | 08:36 PM
  #26
tmacie's Avatar
tmacie
BWDAKRT....Will the ford injectors fit our rails and intakes with the stock ford orings and such or do you have to use the dodge o-rings?
Thanks,
Travis
Old Jul 5, 2012 | 08:58 PM
  #27
O-rings are the same. Direct fit.
Old Jul 5, 2012 | 09:03 PM
  #28
tmacie's Avatar
tmacie
Velly nice! I have a plenum plate and gasket waiting for me to install. Looks like a perfect time to install new injectors!!!
Travis
Old Jul 5, 2012 | 11:01 PM
  #29
bwdakrt's Avatar
bwdakrt
Thanks,
Travis
The man is exactly right. A very simple plug & play as long as you get the ones with the matching connectors for your year model truck.
'92-'99 - EV1 Rectangular shaped connector
'00 + - EV6 Oval shaped connector
Old Jul 5, 2012 | 11:07 PM
  #30
QuadCabLuv's Avatar
QuadCabLuv
^^ good info here. After i get my headers and exhaust done along with a 14x3 i will probably upgrade to these injectors. Im sure they may help with heavy loads i tend to pull, not 20k lbs, but still.
