Headlight/foglight switch
Ok thank you
With your Highs on the fogs will not work, there is something more likely in the switching relay in the pdb under the hood that controls this. I know which one it is for a 96 but not for a 99. I will go look in the fsm and get back.
Q Your outside low and highs work.
nope, switch look just fine, not melted or f'ed up. I even took it apart to see if anything was broken, bent the tabs for the fog switch a little more to. I don't recommend to take that a part unless you are in for a good pita challenge when comes time to put it back together
New bulbs x 4, new switch, new relay, all fuses good to go. FFS, what am I missing? Still no fog lights and no quad lights, when is ot that the quad lights are on?? All the time, highs and lows?
Does this pix correspond to you're findings for power and ground? If you have both there it must be in the plug wiring order.
This is looking into the back of the bulb socket.
Thanks HeyYou, I have never seen these lights on so that helps to know.
merc, I will check again tomorrow, it's been a couple days so I have to go back under the hood to remember and double check.
Thanks guys
Thanks guys
