battery cable question
Old Jul 6, 2012 | 09:36 PM
mideerslayer's Avatar
mideerslayer
Default battery cable question
First time posting
I just picked up a 1996 dodge 1500 ext cab 360 4x4
Runs drives etc, I was going over the truck and I notice there is a smaller black wire coming from the battery cable at the (post) and it isnt hooked up to anything, what is this wire for? You can tell it is part of the battery cable and not aftermarket.
Thanks in advance, I will be posting and reading this site a lot
Rich
Old Jul 6, 2012 | 09:46 PM
If it goes to the negative battery cable, probably a body ground. Look for the other end of the wire where it can reach the body.
If it's to the positive side.... heaven only knows.
Old Jul 6, 2012 | 10:47 PM
mideerslayer
I forgot to mention it is the negative side, so I will assume its a body ground wire, as that is about where it would attach.
Thanks for the help
Old Jul 6, 2012 | 11:32 PM
'nother michigander?
Old Jul 6, 2012 | 11:40 PM
mideerslayer
Yes sir, I am from Clinton Township.
I just picked up this truck, as I have always wanted a ram, since my dad built them up untill 93 (medical retirement/Passed that same year) and he always wanted to get a "t-300" as the new body style was called.
So I finally got one and now I get to start the fixing.
Runs great just needs a few things
Old Jul 7, 2012 | 10:30 AM
Welcome to DF.
Old Jul 7, 2012 | 01:30 PM
charlie1935's Avatar
charlie1935
He called you sir, Hey You!
Old Jul 7, 2012 | 08:20 PM
ReadRam's Avatar
ReadRam
On my 99 there is a body ground,smaller black wire from negative post, that is attached above the head light on top of fender. There's a post with rubber mount..attach to body anywhere near there, should be good.
Old Jul 8, 2012 | 03:20 PM
zman17's Avatar
zman17
Retired Moderator - RIP
This one?
Old Jul 8, 2012 | 03:28 PM
gdstock's Avatar
gdstock
There should also be some between fender and radiator support or frame, engine to frame, engine to firewall. Several grounds, all are needed...more is better....
