On board air?
Old Jul 12, 2012 | 04:18 PM
Sooper's Avatar
Sooper
Here are some pics of the York compressors and brackets I have at home.
Modified 210 (The one I used.)
Unmodified 210 (Not tested or used. Planned for use on a 440.)
Unmodified 210 (Not tested or used.)
Unmodified 209 (Not tested or used.)
The 1st pic has the compressor mounted to a bracket that mounts to the pre Magnum engines. The following bracket is one I think I picked up for a big block.
Old Jul 27, 2012 | 10:32 PM
Goatley's Avatar
Goatley
hmmm I might have to go this route...
Old Jul 27, 2012 | 11:00 PM
gdstock's Avatar
gdstock
Sooper...your tools are WAY too organized!
Old Jul 30, 2012 | 11:06 AM
Sooper's Avatar
Sooper
Ironic you should say that, because when I have the time and some extra cash I plan to take it to the next level.
I want to insulate the side brick walls with a 2x2 structure and drywall. Paint it white or light grey with a blue belt stripe. Brighter florescent lighting. Mount a 42" TV in the upper corner, epoxy coat the floor, paint all the engine stands and hoists a nice clean blue and replace all the wheels with rubber or nylon castors.
I want to build a duplicate bench to the one I have, clean and paint them, and integrate some sort of bench top pad that is removable and washable...like an oil mat of some sort. Up until now I have been stapling old towels to the replaceable plywood surface.
The pegboard backing is going to get framed in trim and painted with the rest of the garage and I'll purge all the unused tools to make room for more tools I plan on getting between now and then.
To me, a garage / work area needs to be clean and organized. It makes jobs to quick and easy when you have quick access to all tools and everything is fast to put away when they all have their own spot.
Old Jul 30, 2012 | 11:08 AM
At one time, I had an old Stainless Steel lab table that I used as a bench. I WISH I still had that......
Old Jul 30, 2012 | 11:35 AM
Sooper's Avatar
Sooper
My work bench is angle iron that's welded together. I have a lower shelf and an upper surface. Both are made so that 4'x2' pieces of plywood drop right in so I can remove them if and when they get damaged. I cover them with something soft and absorbent.
The lab tables are cool but very loud. Also, slippery, when fluids are involved...which in my garage is fairly often.
