Radiator ?
Old Jul 15, 2012 | 06:21 PM
pcfixerpro's Avatar
pcfixerpro
Default Radiator ?
Truck - 01 1500 5.2L 4x4
So the top rib of my radiator is bending up. Most likely from leaning over the front of the truck over the years when doing tune-ups, looking down the TB, etc.. It isn't leaking yet but I decided to look at radiators tonight as I will replace it before a problem develops.
Anyway... to the point. I am surprised there are more than one radiator between the 5.2 and 5.9L.
If I look it up at autozone, it says I should get a CU1552, and if I look it up for a 1500 5.9, it says CU2291.
What prompted the problem was when i looked at Napa to compare price and saw the CU2291 for my 5.2L truck listed.
Bottom line... does the 5.9 one have an extra core? The spec numbers are slightly different in height and width. Would I benefit from the 5.9 radiator, or stick to what it says. I ran into this same issue with Spectra parts in the past when i put in my heater core. Two different numbers (one flex pipe, one hard line). Wish they could make this easier.
Old Jul 15, 2012 | 09:04 PM
Are they both from the same manufacturer? If so, go with the meaner radiator. If you are going to replace it anyway, why not upgrade? It should bolt right in, and hook right up.
Old Jul 15, 2012 | 09:19 PM
pcfixerpro's Avatar
pcfixerpro
Both from the same manufacturer. I'm not sure if one is meaner than the other lol. One does cost more than the other though (about 50ish from autozone)... but i'm surprised there is a difference between a 5.2 rad and 5.9 rad to begin with. I was hoping someone may have known the difference between the two for the extra cost.
btw, 20k posts? Impressive
Old Jul 15, 2012 | 09:32 PM
dhvaughan's Avatar
dhvaughan
from Summit's web site. this makes no sense. the 1552 is listed for all 3 engines at $116. The 2291 is listed for 5.9, is one inch SHORTER, and costs $149. It says both are single core, and same thickness.
CU1552 - Radiator, Aluminum/Plastic, Dodge, 3.9, 5.2, 5.9L,
$116
Brand Spectra Premium
Mfg Part Number 434-CU1552
Part Type Radiators
Product Line Spectra Premium Radiators
Summit Part Number SGT-CU1552
Radiator Style Crossflow
Row Quantity Single-row
Radiator Finish Natural
Radiator Material Aluminum/Plastic
Transmission Cooler Yes
Inlet Location Upper driver side
Inlet Size 1 1/2 in.
Outlet Location Lower passenger side
Outlet Size 1 3/4 in.
Core Height (in) 32.625 in.
Core Thickness (in) 1.250 in.
Core Width (in) 19.250 in.
CU2291 - Radiator, Aluminum/Plastic, Dodge, 5.9L
$149
Mfg Part Number 434-CU2291
Part Type Radiators
Summit Part Number SGT-CU2291
Core Height (in) 31.625 in.
Core Width (in) 19.375 in.
Old Jul 15, 2012 | 09:49 PM
gdstock's Avatar
gdstock
Either of them should bolt into the radiator support. Checking part numbers for rad support, it is the same regardless of engine. I did not see a differnce in part number for radiator either, but I got distracted. If one has more cooling capacity, I would get that one...more rows or thicker would probably be the only way it would be different. Have AZ call their VDP line to have them check....
Old Jul 15, 2012 | 11:14 PM
I think "post *****" is the term you are looking for.
Seems the 1552 is an inch taller core, but not quite as wide.....
