radio wiring trouble
Old Jul 16, 2012 | 03:08 PM
beckman's Avatar
beckman
Default radio wiring trouble
hi guys i have a 1998 dodge ram truck and i have a cd player im trying to install but the wiring i cant get matched up it has wires on the cd player but when hooked up with matching colors it doesnt come on any help would be greatly appreciated thank you very much
Old Jul 16, 2012 | 03:42 PM
Wire color is not the issue, it's what the wires DO that is important. Do you have a schematic for the cd player? OR, is anything labled on the back? Might be able to find something online if you look hard enough. Also grab the 01 service manual, so you know what wires do what on your truck. If you have the Infinity sound system, it's gonna be even more complicated.
Old Jul 16, 2012 | 04:24 PM
crazzywolfie's Avatar
crazzywolfie
with the very little info you have given use i don't know what you are talking about. are you trying to install an aftermarket stereo?
this might help you
http://www.installdr.com/Harnesses/DCP-Wiring.pdf
Old Jul 16, 2012 | 09:56 PM
Ramzy's Avatar
Ramzy
Yep wire color on aftermarket systems has nothing in common with factory wire colors. You need to go online and download the installation instructions for the aftermarket unit you are using and like HeyYou said grab the FSM for the truck. Also a radio installation kit for your truck will make easier work of the job. First thing first disconnect the radio you installed before you start melting things.
Old Jul 17, 2012 | 11:07 AM
ZeroZero3's Avatar
ZeroZero3
google is your friend
Old Jul 17, 2012 | 11:25 AM
brewman's Avatar
brewman
It also makes a difference if your truck had the OEM infiniti sound system. If so you also have to make sure you tie the new player's amp/remote trigger to the wire that activates the amps in the doors which drive the door speakers.
Old Aug 26, 2012 | 11:30 PM
Vinny- collins's Avatar
Vinny- collins
Hey I have a 95 Dakota and I took the old radio out because it would have its fits of not working and my buddy gave me a Chrysler fm/am cb radio I got the wiring figured out on the trucks side but I don't know what dose what on the stereos side I know the 12v+ and I found the ground but I don't know what wires out put sound
