1998 dodge ram 1500 Problems Shifting
Old Jul 22, 2012 | 02:17 PM
ArmyBaptist's Avatar
ArmyBaptist
To tell you the truth hey you I was so upset when I took the pan down that I didn't think about taking pics the pan was FULL and I mean full of metal shavings. After I saw that with the problems I was having I just wanted to get my truck back up and running now to start treating this truck like it should have been treated.
Old Jul 22, 2012 | 02:43 PM
Ah well.
For future reference though, we are indeed pic ****** here....
At least you will get your truck back.
Old Sep 17, 2012 | 01:02 PM
20dakota02's Avatar
20dakota02
Default Dakota trans problems
Sorry for the delay in responding, here is my update. Replaced the governor pressure solenoid an transducer. Also replaced filter, fluid an adjusted bands. Truck Is a 2002 Dakota 3.9 with 96,000 miles fluid looked good an no burnt smell. Put back together road tested and everything worked great, up and down shifted properly. Next time out problem is back!? But the original code was P1756 now I am getting code P0748? I have not found any wiring issues yet, can someone give me more ideas? Is there any way to test PCM?
Old Sep 18, 2012 | 12:05 PM
P0748 Governor Press Sol Ctrl/Trans Relay Circs
Check all external connections, especially the ones at the PCM. They like to corrode.....
Check connections at the trans relay as well.
Old Sep 19, 2012 | 08:03 AM
20dakota02's Avatar
20dakota02
Thank you for responding. PCM connections looked good, the Trans relay connection is not going to be easy to get to but I will try again. Odd thing is if I start the truck in neutral the trans shifted fine at least during the five mile road test? I may spray the PCM connections anyway just is case some coating is on the pins that I can't see.
Old Nov 27, 2012 | 06:51 AM
jawsfree's Avatar
jawsfree
Was the issue resolved? I am having a similar issue on my 1996 B2500 van.
Old Nov 27, 2012 | 12:53 PM
ss/tram97's Avatar
ss/tram97
try to unplug the oxygen sensor before the cat that is the main power source for the transmission and if the sensor is shorted it will display 1756 if while unplugged it shifts fine replace the sensor and you will be good to go
Old Nov 28, 2012 | 07:53 AM
20dakota02's Avatar
20dakota02
Default Trans shift problem
Have not done or found anything since my last post, trans still shifts fine until you make your first stop, then will not shift automatically? But, all you have to do is restart it and I can drive it all day and it shifts like it should. You can turn it off for hours and it will still shift fine but let it set overnight next day same thing, I drive to the first stop sign turn it off then restart, I'm good to go all day.
I will check to oxygen sensor like you suggested.
Thanks
Old Nov 30, 2012 | 08:10 PM
goofyonehasu's Avatar
goofyonehasu
Default 99 dodge 1500 4x4
Trans not shifting i put 2 bottles of Lucas Trans it works good know
Old May 4, 2013 | 09:13 PM
mrs_scs's Avatar
mrs_scs
had my tranny rebuilt and the guy did a great job. check enine light was on before trans mission went out. got the tranny back in checked the codes for the light and it came up 1762 and 1763 changed the gov. sensor and solenoid out and this set of codes went out . But now have a p0748 showing. checked the trans relay under the hood. traded the horn relay with the trans relay. Relays numbers were the same for each. tranny will not down shift. looked up the code. i dont know where the control and shift solenoids are. the guy who did the rebuild is on vacation in FL. for about a month!!!! lucky guy!!! any ideas??????
