Brake Line Ruptured
Old Jul 19, 2012 | 10:51 PM
soloflite's Avatar
soloflite
Thanks all, got a 25' roll from A/Z along w/ new fittings and new rear brake hose. New brake hose is installed, old line pulled. Will bend new line tomm. am. and install, bleed..
thanks for all the help
Old Jul 20, 2012 | 01:09 PM
soloflite's Avatar
soloflite
Thanks again, got a new run from the front to the back, all is good, system bled, all new fluid and brakes GREAT!
Old Jul 22, 2012 | 09:56 AM
Amy Brossart's Avatar
Amy Brossart
I busted my line somewhere between the gas tank and the frame on the back drivers side.... But I can't see it.. I can only see all the fluid pouring out back there... Do I have to drop my tank to find this and fix it?
Old Jul 22, 2012 | 10:08 AM
kejobe's Avatar
kejobe
No. Just run a new line from the "t" behind the left front wheel to the flex line in the rear. I didnt even remove the old line on mine when it blew out, just used zip ties to hold it up.
Old Jul 22, 2012 | 10:11 AM
Amy Brossart
did you have to drop your tank to find and fix it
Old Jul 22, 2012 | 10:16 AM
kejobe's Avatar
kejobe
No, I didnt drop the tank. I just ran a new line.
