p0304 again and again
Old Jul 22, 2012 | 11:54 AM
1&2genrams's Avatar
1&2genrams
Default p0304 again and again
I already searched and read alot of the same CEL code, my problem seems to be a little different....out of the blue I get a p0304 code, I pulled the #4 plug and the electrode is mostly missing, it looks like it burned/melted off,all the others looked good,(plugs were only about 4 months old)after a new set of plugs its good for a few weeks...then....p0304 is back....the plug looks good...the wires were new before the burned plug,(new MSD's)...Im going to re-route the wires according to the TSB.....but why the burned plug only on #4? pre-ignition on one cylinder only? vacuum leaks? is there any hoses or any other sources of vacuum leaks that would relate to that one cylinder only?
thanks in advance
Old Jul 22, 2012 | 01:07 PM
Do a compression check.... Seafoam the engine. (thru the brake booster hose.) Swap the #4 injector with #2, see if the problem moves.
