Cannot get Transfer case plugs out
Old Jul 21, 2012 | 10:29 PM
RageGuy's Avatar
RageGuy
Default Cannot get Transfer case plugs out
I'm a fairly strong guy...but I am twisting the hell out of these damn plugs with everything I got and I cannot BUDGE either of them (Yes, I tried the fill plug first), but I also tried to even loosen the drain plug even a tiny bit and nothing.
I sprayed some WD-40 on em...gonna let it soak for a while..hopefully that loosens them up.....Using heat on those probably is NOT a good idea hey?
Any other suggestions?
Old Jul 21, 2012 | 10:34 PM
WD-40 won't work, it isn't a penetrating rust dissolver. You need some PB Blaster, or similar product.
With the right stuff, spray a bunch on, and then tap on the plug with a hammer. (not hard, just tap.) Do that a couple times, and then try and remove them.
No, you don't wanna use heat on aluminum....... that could be bad.
Old Jul 21, 2012 | 11:11 PM
dhvaughan's Avatar
dhvaughan
be careful on wrench size choice. the hex plugs are 10mm, not 3/8.
if penetrating oil doesn't work, look for a 10mm hex you can insert into an impact wrench. the shock of the impact 'should' break it loose.
(or a long breaker bar on a socket style holder)
edit - a little bit of heat might not hurt. just remember, aluminum melts at around 600 or so.
Old Jul 21, 2012 | 11:41 PM
RageGuy's Avatar
RageGuy
Got em loose, I want to go back in time and slap the crap out of myself for over-torquing those whenever I did this last, LOL.
Had to use both your ideas....Went and bought some actual penetrating oil, let it soak for 20 mins, then attached the longest ratchet handle i could find and let er rip....still took a crap-ton of force..
oh well, Cheers!
Old Jul 21, 2012 | 11:47 PM
dhvaughan's Avatar
dhvaughan
when you reinstall them, use a thread lubricant like RTV or liquid teflon. then just barely snug them.
Old Jul 22, 2012 | 12:46 AM
gdstock's Avatar
gdstock
...or something like never seize....
Old Jul 22, 2012 | 08:32 AM
dhvaughan's Avatar
dhvaughan
i like to use anti-seize on things that you torque down tight, or modestly tight, especially spark plugs and lug nuts.
for oil/coolant drain plugs, i like to use liquid teflon and just barely snug them. the teflon (or rtv in a pinch) will prevent seizing/galling, seals it up, and prevents back out.
Old Jul 22, 2012 | 02:22 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Torque them to the proper spec. 35ft pounds and you wont have that problem again.
