truck dies
Old Aug 1, 2012 | 08:15 PM
jshm52's Avatar
jshm52
Default truck dies
well on my way home from work today my cel came on and the truck then dies. It will only run if i press on the gas if i let off it dies. got home and pluged in my scanner and got a po505 code. so i cleaned the iac and still the same thing. put a new iac in and still the same thing. checked all wireing and all looks good. Bad pcm?????????????? any thoughts need a lil help. 97 dodge ram with a 5.9
Old Aug 1, 2012 | 08:57 PM
95RAM360's Avatar
95RAM360
Have you checked fuel pressure? Sounds like your pump is going out
Old Aug 1, 2012 | 09:14 PM
jshm52's Avatar
jshm52
no i havent. never thought to check it cause when i keep it running it runs fine. just when i let off the gas it dies and always starts back up if i give it a lil throtle.
Old Aug 1, 2012 | 10:03 PM
ReadRam's Avatar
ReadRam
Did you clean out the port where iac pintle closes against? Reset pcm, pull neg on battery?
Old Aug 2, 2012 | 08:08 AM
Also check and clean the connectors AT the PCM.
Old Aug 2, 2012 | 06:05 PM
jshm52's Avatar
jshm52
Thanks guys for the help but i have already cleaned everything on the throtle body the iac and all concetions at the pcm. any other ideas??????????????
As long as i keep a lil bit of throtle it will run and runs flawlesy as soon as i let off it instatly dies.
Old Aug 3, 2012 | 09:19 AM
PoppaRam's Avatar
PoppaRam
Have you checked the TPS
Old Aug 3, 2012 | 09:23 AM
QuadCabLuv's Avatar
QuadCabLuv
Also have your battery and alt tested. Mine would run if i kept it at 1200 rpm but would stall right out if i let it drop any. Turned out to be a dead battery cell and weak altenator.
Old Aug 3, 2012 | 10:58 AM
Ham Bone's Avatar
Ham Bone
My battery was dead and I had the exact same thing happen. It don't cost anything to get your battery tested so go it tested. If its old I would just go ahead and replace it
