Brake bleeder screws rusted tight....
Old Aug 2, 2012 | 10:38 PM
crazzywolfie's Avatar
crazzywolfie
if you are looking at gm parts you had better make sure it has the 1 3/16" bore. if they have a 1 1/16" they are pretty much the same as the dodge 1 tons but they would all beat the 1500's stock 15/16" bore wheel cylinder.
i think if you are going replace all the caliper and wheel cylinders you should go ahead and spend another $100 and replace all the brake lines and fluid. you will most likely break the ones at the rear cylinder when you try to change them.
Old Aug 2, 2012 | 11:30 PM
stewie01's Avatar
stewie01
Originally Posted by VWandDodge
Provided he has the wheel cylinder or caliper removed from the vehicle; otherwise, that brake fluid is going to boil and "BOOM", the weakest point is going to give.
This is why, when I install new cylinders/calipers or refurbish either that I put a light coat of anti-seize on the bleeder valve before installation.
I'd think you'd have to torch the **** outta it to get the brake fluid hot enough to boil and go BOOM.
Old Aug 3, 2012 | 08:20 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Nope. I've done it several times parting out old VWs when I couldn't get the brake like off the wheel cylinder. The old VWs have a soft line on the rear brakes and when heating the bleeder or the "nut" that attaches to the wheel cylinder will boil the fluid and cause the soft like (which will have collapsed internally) to pop due to heat & pressure.
Old Aug 3, 2012 | 09:03 AM
Torch gets things SIGNIFICANTLY hotter than even riding your brakes while stepping on the gas could ever even consider.....
Old Aug 3, 2012 | 09:11 AM
stewie01's Avatar
stewie01
Well I just got schooled
Old Aug 3, 2012 | 08:01 PM
Jason_Dodge's Avatar
Jason_Dodge
Just get new ones. Got both of mine for 40 dollars.
