flat tappet cam in a magnum???
Old Aug 5, 2012 | 11:17 AM
my99ram's Avatar
my99ram
Default flat tappet cam in a magnum???
got my 99 318 magnum taken apart and was wondering if a flat tappet cam and lifter kit will work or if I have to stay with a roller
Old Dec 21, 2021 | 03:17 PM
Gary Benoit's Avatar
Gary Benoit
you can use a flat tappet cam and lifter in the 5.2L, May have to tune the PCM
Old Dec 21, 2021 | 08:46 PM
AtomicDog's Avatar
AtomicDog
Question
Just curious - why would you want to use a flat tappet cam over a hydraulic roller cam?
Old Dec 22, 2021 | 06:49 AM
Moparite's Avatar
Moparite
Price probably.
Old Dec 22, 2021 | 09:38 AM
Originally Posted by Moparite
Price probably.
So instead of spending money on the cam, you can spend the money on adapting the heads to accept some variety of adjustable rockers?
Old Dec 22, 2021 | 10:01 AM
Mike Holmen's Avatar
Mike Holmen
You may also need to modify the rocker arm oiling, as the magnum motor rocker arms get oil thru the push rod tubes, the older LA engine had a oil from the block into the head/rocker arm shaft. So I'm not sure if the flat tappet lifter will have the provision to allow oil to flow into the push rod tubes.
