2001 ram1500
Old Aug 7, 2012 | 09:40 PM
Ramblin man 66's Avatar
Ramblin man 66
about the oil if your looking at the carb not in the carb ports there was a little black oil on top. I read plenum thread.. and it does say magnum on the side.LOL. i was also told to fuel injector cleaner in the gas tank..
Old Aug 7, 2012 | 09:55 PM
dhvaughan's Avatar
dhvaughan
consider replacing PCV valve. some years are on drivers side valve cover, some on passenger side. hose connects to the side of the intake.
on the OPPOSITE valve cover is a vent elbow with hose going to air filter. air should flow from air filter through engine, through PCV, into intake.
when PCV gets stopped up, oil soaked air from engine, under mild pressure, vents up to air filter. that's where your oil is coming from.
Old Aug 7, 2012 | 10:23 PM
Ramblin man 66
I will check that pcv valve. the truck idles fine it does'nt jump up and down. my biggest issue is when you stomp the pedal down it should take off quick. and its like slug. it should shift down and go.. i know its no a hot rod. but if im doing 20mph or 30mph. And i hit the pedal it accelerates very slowly. thats my biggest issue..
Old Aug 7, 2012 | 10:27 PM
QuadCabLuv's Avatar
QuadCabLuv
Try adjusting your kickdown cable, or tv cable as some refer to it.
Old Aug 7, 2012 | 10:48 PM
Ramblin man 66
where should i check for the Vac leak?
Old Aug 9, 2012 | 10:19 PM
Ramblin man 66
I changed the PCV valve and went one click in with the throttle cable and it runs a lot better now it down shifts when i hit the gas and it takes off a whole lot better. Thanks dhvaughan and to everyone else for your input
