Anyone got a CTM to spare?
Old Aug 8, 2012 | 10:23 PM
  #21
yooperbug's Avatar
yooperbug
Thank you so much! We shall see if I get ticked off trying to get to it to change it.
Old Feb 19, 2013 | 05:20 PM
  #22
dodgeman41291's Avatar
dodgeman41291
I do appoligize I have been searching Google and I cant seem to find a new CTM I even called the dealership and they don't even have one, so I was wondering if anyone had one I could buy, I need a high line CTM cuz I got PW, PL, PM, I don't have the high end sound system, or the auto diming mirror.
Old Feb 19, 2013 | 05:27 PM
  #23
gdstock's Avatar
gdstock
Take a look HERE. Also, go to FAQ/DIY section and download parts manual and service manual. FInd part number and call idiots at dealership back. They are available.
Old Feb 19, 2013 | 10:07 PM
  #24
dodgeman41291
Where is the CTM Located? Ive looked under the dash and cannot find it. Im guessing it is somewhere directly below the radio near the floor board under that box thing where there are 2 screws. and it says SRS Airbag its on the floor board... but i don't know if thats to control the air bags or what.
Old Feb 19, 2013 | 10:37 PM
  #25
That box is indeed for the air bags. 95 doesn't have a CTM. Has a timer relay in the fuse block, top left as you are looking at the fuse block.
Old Feb 21, 2013 | 12:28 PM
  #26
dodgeman41291
ok, well I replaced the Time Delay Relay, and I still don't have any Map lights or Dome lights when the door opens, the only time I can get the dome or map lights to come on is by turning the **** on the headlight switch, I went through both fuse blocks and tested every fuse. and like i said previously the chime works when the key is in the ignition and the door is open, but no light.
also on the power block under the hood, I saw a fuse for fog lamps, but I don't have any fox lamps on my truck none the less a button for it.
anyways off topic. any more suggestions, the next thing im going to do is replace the door jam button.
if anyone has any other suggestions please let me know, this is agitating when I can see to get into my own truck at night.
Old Feb 21, 2013 | 12:46 PM
  #27
Do the dome lamps work if you open the passenger door?
Old Feb 23, 2013 | 01:28 AM
  #28
dodgeman41291
Dome/Map lights do not come on from either door, a guy at Advance Auto Parts said it could possibly be in the headlight switch (even tho the lights do come on when i turn the headlight ****)
also, as i previously said, the ignition halo comes on as well when you turn the **** but not when you open any of the doors.
Old Feb 23, 2013 | 10:35 AM
  #29
See if you are getting power on the yellow wires at the door switches.
Old Mar 3, 2013 | 09:11 PM
  #30
dodgeman41291
I havent been able to check the door switches yet because I have been very busy, but i also wanted to add that my windows don't roll down/up when my key is in the accessory position only in the run position do they work
