4x4 problems 4L. ok , 4h. wont engage help
Old Sep 3, 2014 | 01:55 PM
  #41
TrevorWL's Avatar
TrevorWL
Okay so a new Actuator should solve the problem? Is the fork apart of the new Actuator or separate?
Old Sep 3, 2014 | 02:21 PM
  #42
Separate. Verify the problem before spending money. Are you getting vacuum where you are supposed to?
Old Sep 4, 2014 | 06:33 AM
  #43
TrevorWL's Avatar
TrevorWL
Not sure I'm not mic of a mechanic, me and my dad are gonna take a look and if we can fix it just gonna get a new one or tie the gear shifter back so it stays in 2H and fix in winter since it won't be going far.
Old Sep 4, 2014 | 09:52 AM
  #44
Start the engine, leave trans in park, t-case in 2wd. Pull the vacuum connector off the cad. should have vacuum on the OUTBOARD port. If you do, shift the t-case to 4wd. Vacuum should now be on the INBOARD port. If you get vacuum in the correct place, in each position, then the actuator *might* be bad. If you don't have vacuum in the right spots, need to find out why.
Old Sep 5, 2014 | 03:43 PM
  #45
TrevorWL's Avatar
TrevorWL
Okay I'll try that tonight if I get time.
