Help! On Highway and truck is throwing a CEL code
Old Aug 10, 2012 | 09:51 AM
DodgeRider1500's Avatar
DodgeRider1500
Angry Help! On Highway and truck is throwing a CEL code
Hey guys, I am in the middle of moving from NorthWestern Ontario to Southern Ontario. After about 4-5 hours of driving/towing my truck started to have a jumpy RPM of about 200-300 and it started to miss. Or atleast thats what i think it sounded like. And now the check engine light is on and is giving me a Code 43. It feels like the power in the truck has vanished and I really have to run hills to make it without dropping to half the speed limit. I looked up the code but I have no idea what it means or how to fix the problem. I am getting terrible mileage now and I still have about 12 hours of driving to do. Any help would be appreciated
I have done alot of work on the truck in the last 2-3 months preparing for the move: Modded Kegger, Hughes IM kit, new exhaust/cat/ and pipes, 2 new O2 sensors, new rad and the list can go on..... It is a 97 Ram 4x4 Regular can 8 foot box. I am in desperate need of help because the more gas I burn, the bigger the whole in my wallet gets.
Thank you,
-Josh
Old Aug 10, 2012 | 09:56 AM
dhvaughan's Avatar
dhvaughan
according to the internet, code 43 is a coil circuit fault.
here's a more dodge truck specific thread with a LOT of detail
https://dodgeforum.com/forum/2nd-gen...code-43-a.html
short and sweet summary
In laymans terms, the voltage is too low and, the amount of time is not being met. That's what that means. Usually, it's a failing coil but, NOT ALWAYS as bad wires will also throw that out as well. I've had that happen with a new coil. Now, as to what else is causing this to occur:
- bad ignition wires
- bad plug
- bad coil / faulty coil / intermittent coil
- bad coil WIRE, faulty (leaky or open)
- low voltage to the coil on the PRIMARY side. Now, what's primary? The coil is a transformer (xfmr) and, at the input side, (the primary) is where the voltage comes in at one voltage (in this case, it's 12V) and is stepped up inside to 30-40 kV at the secondary respectively.
i'd check all plug wires, listen for a skip to maybe replace one plug, and probably replace the coil. its quick and easy and not too expensive.
Old Aug 10, 2012 | 10:06 AM
DodgeRider1500
Ok I just ran out and checked. there was one spark plug that seemed to be abit loose, it kind of clicked when I pushed on it. Hopefully that was the problem, ill see when I get back on the road. Thank you so much for the quick response, I really appreciate it.
-Josh
