PCV valve and spark plug question.
Old Aug 13, 2012 | 02:54 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by RareColorRam1995
I finally got it out. Actually, I was pulling on the crankcase breather on the passenger side of the engine. Apparently, a 1995 318 and a 2001 360 have backwards setups on the location of the PCV :/ I felt like such a dumbass.
I should have said something yesterday, I knew you pulling on the breather elbow, not the pcv . Sorry.
Old Aug 13, 2012 | 05:07 PM
RareColorRam1995's Avatar
RareColorRam1995
It's cool zman, you've been awfully helpful in the past!
Old Aug 13, 2012 | 05:34 PM
zman17's Avatar
zman17
And hopefully in the future.
Old Aug 13, 2012 | 11:09 PM
hbarker's Avatar
hbarker
hmm So those 426 pluggs a little cooler than whats stock?
I was looking for plugs today , I had it wrote down is Autolight Copper 3923 cooler than stock?
Old Aug 14, 2012 | 03:20 PM
zman17's Avatar
zman17
Its 436 and they are just stock heavy duty truck plugs. The 3923's are cooler than stock. No need to use them if you have fixed your plenum, cat,o2's and checked for the death flash. In which case you'll want a tuner, and depending on what you purchase for a tuner, you may want to use the 3923's. I suggest you do some reading around here on DF.
Old Aug 15, 2012 | 02:21 PM
hbarker's Avatar
hbarker
Hmm wish I had read that this morning. I thought I done good .........? I have fixed my plenum, cat,o2's
, I tell ya i had to go to 5 parts stores to find those 3923's. Napa only one had em. 1.77 cents each !! just put em in this am.
My tuner is a SCT . Should I have left the dang plat in it?
Speaking of pcv vavle that little booger in my truck was sounding like a rattle snake!
Old Aug 15, 2012 | 02:24 PM
zman17's Avatar
zman17
, I tell ya i had to go to 5 parts stores to find those 3923's. Napa only one had em. just put em in this am.
My tuner is a SCT .
Walmart also has 3923 Autolite's
Old Aug 16, 2012 | 10:38 AM
hbarker's Avatar
hbarker
Ahh man , after changing those plugs, Got out my SCT programmer and it dont work anymore :0. OMG
Dont remember if I have the factory tune or the 89 tune on my truck currently,
Only reason I changed those plugs was to use the 91 tune, Damn.
The sellect button is unresponsive . One year and 28 days old, used one time.
Old Aug 17, 2012 | 01:58 PM
zman17's Avatar
zman17
Did you buy it from Hemifever?
I just noticed a ? you asked. You fixed the plenum, but used the original steel plate?
Old Aug 18, 2012 | 05:04 PM
ReadRam's Avatar
ReadRam
Go get dealer PCV. I got one from O,O,O,O'Reillys and also thought had a rattler in the dash. Tracked down the racket to oversized PCV. Didn't notice it until after relpacing valve cover gaskets. Side note: I reused stock steel pan on plenum repair.
afraid it might have blown again, did the vacuum gauge in breather hose with PCV hose blocked off. Went for 25 seconds and got positive flow of 2-3 lbs, no vacuum.
