PCV valve and spark plug question.
Old Aug 18, 2012 | 05:31 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by ReadRam
Go get dealer PCV. I got one from O,O,O,O'Reillys and also thought had a rattler in the dash. Tracked down the racket to oversized PCV. Didn't notice it until after relpacing valve cover gaskets. Side note: I reused stock steel pan on plenum repair.
afraid it might have blown again, did the vacuum gauge in breather hose with PCV hose blocked off. Went for 25 seconds and got positive flow of 2-3 lbs, no vacuum.
I figured you reused the steel pan. If you have to reuse it again, use a Felpro gasket and shorter bolts that hold the pan on. Or cut the the tips off the stock bolts.
Old Aug 31, 2012 | 12:27 AM
  #22
hbarker's Avatar
hbarker
I used the Hughes alliminum kit
