Death wobble info from chrysler
The steering wheel shakes violently side to side and the front end wobbles and bounces like it wants to escape from the vehicle. You'll know it if it happens!
wow I'm surprised my in laws didn't mention that fox news item, the wife and I always have a couple Jeeps in the stable and they've been on the "Jeep is a death trap" wagon since we bought our first Wrangler, they just love bringing up any news item that puts Jeep in a negative light.
What's more unnerving then having deathwobble strike you is seeing it happen to the guy in the lane next to you at 70 plus MPH.
thankfully anytime I've had death wobble I've never had a to go in circles figuring out the cause. my ZJ got it when an axle shaft ujoint was on it's last leg, TJ got it when passenger side front tire became unbalanced, and my WJ was because when we did all the tie rod ends we ended up with over an inch of toe in. All three times it was a quick diagnose and fix
****UPDATE**** if you've read my story about the Death wobble, to cut to the chase, I decided to replace the steering stablizer and cured the problem..
I Pin pointed my Death-wobble experience and concluded
1. Bad Lower Ball joints (Hopped/ Bounced up& down)
2. Bad Stablizer shock (bounced side to side)
Now i just need to adjust the (steering box) since i Have a really hard steering problem, unless i put it back together Wrong after the OverHaul.
