98 1500 trany problem
Old Aug 13, 2012 | 08:28 PM
Craig Deboer's Avatar
Craig Deboer
Default 98 1500 trany problem
I have a friend who is a girl. Has a 98 dodge ram magnum that is having trany problems. It has no reverse. Well go into drive just fine and drive great still. Shifts good. No slipping. But when your in reverse have nothing.
has 160k on it. Fluid is burnt but its still is red when you whip it on a white rag.
So I'm thinking its just a reverse pack or maybe a ban. Not really sure but would really love the help.
Old Aug 14, 2012 | 08:15 AM
Drop the trans pan, and see what parts you find laying in it. My guess is one of the band struts fell out.
Old Aug 14, 2012 | 01:33 PM
Craig Deboer
On. I'll try that. Are bands pretty easy to replace? And am i just stupid and can't see it or isn't there a drain plug on the trany pan
Old Aug 14, 2012 | 11:44 PM
Jason_Dodge's Avatar
Jason_Dodge
Dont know why manufactures didnt put drain plugs in tranny pans, but no. There is not. There is a pan south of the oil pan that has 14 or so bolts on it and you undo the bolts on three sides of the pan and let the fluid drain out. you then undo the rest of the bolts - a friend to help you lower the pan would be great - and then inspect the insides. Keep in mind, when you lower the pan there is still plenty of fluid in it and thats why you should have a friend help you out.
Btw, if you dont know what you are doing you should most likely have an experienced friend/mechanic help you out.
