Throttle Position Sensor question
Old Aug 19, 2012 | 07:02 PM
dhvaughan's Avatar
dhvaughan
^ i doubt your problem is TPS. it sounds more like a skip (plugs, wires, cap, rotor) or a vacuum leak.
Old Aug 20, 2012 | 07:26 AM
Leastofthese's Avatar
Leastofthese
I already replaced plugs, wires, cap and button, and checked all vac lines. Could it be a sensor on the tranny? When it skips, it acts almost like a clogged injector, but it doesn't skip or miss or hesitate at any other time. Idles fine, holds steady at mid rpm and high... smooth as a sewing machine! Just on takeoff. I don't have a tach, but I would swear it's just between certain RPM with strain on engine.
Old Nov 13, 2014 | 10:23 AM
biggen76's Avatar
biggen76
Default bad tps
The tps can cause all kinds of issues from idle to communication with the tranny causing erratic gear shifts always start with cleaning throttle body if dirty unmetered air can cause codes from o2 sensor to bad tps code once that's done if you got a bad tps code still replace it test with volmeter after replaced it should be between .5 and 1.5 the closer u get it to 1.0 the better to do this leave torx bolts just lose enough that u can move throttle sensor clockwise for up and counter to decrease voltage i may have that backwards but you get the point when u get it as close to 1.0 as u can tighten it down u should notice a significant increase in efficiency and power
Old Nov 13, 2014 | 03:38 PM
Two year old thread......
Old Nov 19, 2014 | 09:59 PM
2000 dodge's Avatar
2000 dodge
I also have a 2000 dodge ram 2500 5.9 360 gas. I also have 1500 to 1700 idle replace the MAP, IAC, TPS and still have high idle. just put new motor in truck. some what cleaned the IAC, AND TPS spots but nothing.
Old Sep 11, 2015 | 11:28 AM
LoneWolfArcher's Avatar
LoneWolfArcher
Not to resurrect this thread again, but I have a question related. Do you need to do the throttle reset procedure on the gas 2nd gens like you have to one diesel 2nd gens?
Old Sep 11, 2015 | 11:43 AM
Just disconnect the battery while you change the sensor. When you are done, hook the battery back up, turn the ignition to "on", (not start) count to ten, then drive it as normal. Should be all you need to do.
