Tranny oil change
Old Aug 26, 2005 | 01:38 PM
venado's Avatar
venado
Default Tranny oil change
im a little bit confused in this issue. i want to change the tranny oil and filter in my ram 1500
auto. trans. but some people have told me that is not a good idea becouse i migth have some future problems could that be true ?
Old Aug 26, 2005 | 01:44 PM
steve05ram360's Avatar
steve05ram360
Default RE: Tranny oil change
no, regular service is the best thing for any auto tranny... get it serviced...
Old Aug 26, 2005 | 04:44 PM
The Burning Rom's Avatar
The Burning Rom
Changing your fluid and filter is a great thing to do. Flushing the transmission (if your truck is high mileage) is what is not such a good idea.
Old Aug 26, 2005 | 04:55 PM
Silver_Dodge's Avatar
Silver_Dodge
Just curious, why would flushing be a bad idea?
You remove more fluid that way. Just dropping the pan allows you to change only about 75% of your fluid. Flush is closer to 100%
Thanks.
Old Aug 26, 2005 | 05:39 PM
steve05ram360
for a flush, if you just replace the fluid it should be fine. draw in fresh fluid from a bucket on the return line from the cooler and dump old stuff into another bucket. I'm not sure if they have any kind of power flush setup at the shop but swapping out all the fluid should not hurt or stir up anything...
Old Aug 26, 2005 | 07:53 PM
DieselDog's Avatar
DieselDog
ORIGINAL: venado
Who ever told you that needs to be smacked![:@] Changing you fluid and filter is part of regular maintainance of a truck and is a VERY GOOD IDEA!
Old Aug 27, 2005 | 12:22 AM
The Burning Rom
ORIGINAL: steve00ram360
Most places that do transmission flushes (at least around here) do it with a compressed air system, or by forcing a cleaning solution through the transmission. Those two techniques tend to stir up shavings/flakes/etc. that have settled in different areas. Some of them make it out. Some of them get stuck other places. That's what can cause problems in a higher mileage transmission.
I've never heard of the bucket technique that you describe, but it sounds like that wouldn't cause too many problems.
In the old days, they used to fill gear boxes up with kerosene and run them around for a bit to clean everything out. I know we did that when we rebuilt our tractor last year. It took 9 gallons of kerosene to fill the transmission...and it looked real nasty when it came out. [:'(]
Old Aug 27, 2005 | 01:11 PM
badram1500's Avatar
badram1500
Just make sure you use the right fluid. Depends on the year of the truck. Don't forget to clean the ckeck valve in the lower cooler line.
