Top shock nut
Top shock nut
I have tried searching but can't find a trick. When I try to get the top shock nut off my 01 2500 the shock just turns. I can't find my strap wrench. I have tried the %$#@ tool a few times. (Grab the nearest tool throw it and yell &$#@) It is almost 100 degrees and humidity you can cut with a knife and I am working in the sun. I know my brain is fried from the sun. So I would ask for people's tricks to get nut off the top of the shocks. I will go drink more water now.
I would heat the nut with the trusty Firewrench and then apply penetrating oil (PBlaster, Kroil, or a mixture of acetone and automatic transmission fluid) to the threads and allow that to soak for a bit.
For future reference, it's always a good deal to apply a light coating of anti-seize to the threads of any fasteners exposed to the elements.
Trending Topics
well, umm not for the top nut on a dodge ram. The place for a wrench or socket is on the top of the stud above the upper nut. Even if there is a place for a wrench under the tower, good luck getting to it. All I can say is that it should have been soaked for a day or so before said replacement.
